BC847 wrote:- Pressure-wash the engine and bay, including underside as it sits so I don't draw back as much black goo on my knuckles.
- Remove stock/OEM oil filter/cooler cover and with a couple of bolts, replace with the marine cooler cover.![]()
- Using few bolts, install the new assembly, less gaskets.
- Be tickled chitless because my earlier ciphering was spot-on regarding the overall fit. (Fingers crossed).
- After getting the general positioning of the assembly right, complete the fabrication of the front assembly mount (to the new oil cooler cover).
- Be pleasantly surprised that I won't have to tweak the passenger's inner fender well. (Fingers crossed).
- Cipher and complete fabrication of 5" down-pipe past the transfer-case including proper mount at transmission bell-housing. (This will take a couple of evenings, or so).
- Cipher and order parts to make hoses and, locate and fabricate remote engine lube-oil filter-head mount.
. . . .. etc . . . .
oldestof11 wrote:Are you sure it is on DECEL the turbos hit the fender and not ACCEL?
The engines spin counter-clockwise when looking from the rear or drivers seat. So when under power or acceleration, it wants to move the frame in a clockwise direction. This pulls the drivers rail up and moves the engine closer to the passenger fender.
spencerdiesel wrote:This is absolutely phenomenal.
BC847 wrote:oldestof11 wrote:Are you sure it is on DECEL the turbos hit the fender and not ACCEL?
It's my thinking that, while accelerating, the engine is (by way of torque) is twisting the truck clockwise, while in doing so, the engine itself is twisting counterclockwise. The head of the engine is pulled to the driver's fender, and the driver's fender toward the head.
- For every action, there's a equal and opposite reaction.
I think that's right.![]()
