6x13 or similar injector tuning
Re: 6x13 or similar injector tuning
Postby spencerdiesel » Tue Mar 28, 2017 3:26 am
How's your 518 liking you these days :D
Postby 79Powerwagon » Tue Mar 28, 2017 8:38 am
I was worried it was going to be miserable to drive after I put the 35s on. But it really didn't affect it too badly.
The 6x13s, yeah I have to ease into it a bit more on a hard pull rather than just blow through the converter but the trans itself bangs gears without a hiccup. I have a build sheet on it from previous owner , built with "hd" parts.
I rolled into it hard on the highway last night at about 65 and it actually set me back a little. I was pretty surprised :shock:
Trying too take it easy til I have the head clamped down good. Oh and a functional egt gauge :lol:
79Powerwagon
Postby Remps » Tue Mar 28, 2017 12:57 pm
The pink/green afc spring in the IC pumps suck once one puts bigger injectors in. A green/black out a N/IC pump or a stiffer spring from the hungry diesel will allow the afc to actually limit low end fuel, instead of beginning movement at 2 psi and bottomed out by 8 psi, for example.
Postby cougar » Fri Apr 28, 2017 9:12 am
I made a .090" spacer for mine. I'm not running as big an injector, 7X.010 SAC but still hazes at idle. The spacer stopped most of the warm idle haze, still does a little when cold.
01 2500 "the work truck".
cougar
Postby 79Powerwagon » Wed Nov 22, 2017 8:08 am
I was reading through some older threads and read something that Eric had said,
He was running a 72lpm injector and found that backing off the timing actually cleared up haze. Now maybe that could have been the 155* spray angle...
Feel I'm getting mixed info on this.
Im going to be plowing with this truck again and want to try to get the idle cleaned up as best I can. (Cold temps,short run time)
What is the best to clean up larger injector haze. Retard timing or skip a tooth(advance)?
79Powerwagon
Postby BC847 » Wed Nov 22, 2017 3:51 pm
As far as cleaning up the burn, you might consider raising the injector's pop-pressure.
Postby 79Powerwagon » Wed Nov 22, 2017 6:54 pm
They are set at ppump pop pressures, more than that?
79Powerwagon
Users browsing this forum: No registered users and 85 guests
