14MM VE H/R
14MM VE H/R
Postby protractor06 » Thu Mar 30, 2017 7:28 pm
I thought I seen a 14MM H/R pump listed on a website and they were claiming 500 CCs of fuel. Is that even possible? Thanks
protractor06
Re: 14MM VE H/R
Postby dazedandconfused » Fri Mar 31, 2017 6:39 am
They aren't reliable and most don't live long. This company is the only one making 14mm heads now that we know of.
http://www.rocken-tech.com/RotorHeads.html
Re: 14MM VE H/R
Postby protractor06 » Fri Mar 31, 2017 11:28 am
Thanks , I have seen the Rocken Tech and just not sure i would do that. Is it possible there are any KTA H/R out there that someone replaced with a P pump? Also it would only run about 15 hooks a year. Are the Rocken Tech H/R just junk? Would it live for low RPM pulling? We are only allowed 3000 RPM Max. Feed it correctly. Maybe it would work?
protractor06
Re: 14MM VE H/R
Postby Remps » Fri Mar 31, 2017 7:27 pm
CPP diesel sells a 14 mm for $650, not sure if it's a rockentech with $240 tacked on or not. Also noticed rockentech sells a 3mm camplate now.
Re: 14MM VE H/R
Postby protractor06 » Fri Mar 31, 2017 8:58 pm
That Interesting. Does anyone know if the 4MM cam works in a 12MM H/R ?
protractor06
