Who likes what lube
Re: Who likes what lube
Postby spencerdiesel » Sat Apr 29, 2017 6:53 am
What oil filters does everyone use? I was running the pure one, then did some research and now I'm using the Donaldson DBL7349 (aka amsoil eao80).
My 1st oil analysis (rotella & pure one) had high silicon indicating dirt. It was 75 ppm. Got the analysis for my last oil sample with delo & Donaldson filter and the silicon is 9 ppm.
Postby Gots_a_sol » Sat Apr 29, 2017 12:24 pm
I run Wix filters. No testing/analysis to say they are great/suck though :lol:
-Joe
Gots_a_sol
Postby spencerdiesel » Sat Apr 29, 2017 3:10 pm
How long after startup is it before your oil press. light goes out?
Postby PToombs » Sat Apr 29, 2017 6:21 pm
Fleetguard all the way! Plus I get them at work for cost. ;)
Postby Remps » Sat Apr 29, 2017 10:34 pm
Most oil filters that I know of have the bypass open around 15-20 psi, and a healthy cummins puts out way more than that at start up. So it really shouldn't matter how much a filter media restricts flow, one should get oil pressure at about the same time. If I was rich I would run a stainless oil filter as a pre-filter, a regular filter, and a Frantz bypass filter. I would want the stainless because they flow a lot more and are much less likely to bypass, therefore they'd catch potential debris immediately instead of eventually.
Postby 79Powerwagon » Sun Apr 30, 2017 7:27 am
I started running a Baldwin BD7317. It's a 30 & 5 micron in one canister, used on reefer units with long service intervals. I change oil regularly about 5k though with Dino oil. Don't really believe in the synthetic 20k+ intervals
79Powerwagon
Postby spencerdiesel » Sun Apr 30, 2017 2:45 pm
Oh and I stocked up with 11 gallons of delo when I saw the local wally with all ck4 oils now.
Postby laneends » Fri May 26, 2017 4:21 am
spencerdiesel wrote:How long after startup is it before your oil press. light goes out?
I was going to ask a similar question. My light goes out immediately, but my isspro mechanical gauge takes much longer than I'm comfortable with to come up. Once it does its almost 80 PS cold, 55ish at 180, and gets kinda low idling after a hard pull up a grade when engine is at 200 or so....
1990 D-250 with getrag 360: pyro, boost, volt, oil pressure, fuel pressure, and water temp gauges, hot screw, 366 gov spring, THD pin, M&H dynamic timing spacer, throttle linkage adjusted for full travel, 4" turbo back exhaust, THD's LPPLP, BHAF, south bend clutch. THD 5x13 comps, 362sxe, 3" crossover, pump to the head
laneends
Postby spencerdiesel » Tue May 30, 2017 3:27 am
Yea I need to get a gauge. I wonder about the factory oil light, mine is on for 3 seconds at every startup. Hot or cold
Postby branumhawk » Sun Jan 07, 2018 6:53 pm
spencerdiesel wrote:Thanks. Who fills their getrag with what?
Synthetic 5W30 a quart and a half over specifications. Used Royal Purple. Been doing the job for 25000 miles since rebuild.
93 W250 getrag single cab.
branumhawk
smoke screw?
Postby spencerdiesel » Mon Jan 08, 2018 8:34 pm
I've got some leftover redline mt90 I've been thinking about trying, thé delo 15w40 is doing fine right now though
