kyled19 wrote:would a first gen 4x4 trans crossmember work with a 4x4 47rh and tcase? I may end up doing custom suspension anyway just for better ride quality than leaf springs. Second gen donor trucks are much easier and cheaper to find in my area. Also will a second gen tcase work with a 4x4 a518?
kyled19 wrote:Does anyone know the differences between 94 frame and a 93 frame? would it be possible to use a 94 or 95 donor truck so I can make the swap to a 47rh at the same time as the 4wd swap.
