Feels like I have no turbo
Postby 92cummins89 » Sat Jul 08, 2017 7:56 pm
I swapped in an he 351cw
I hooked up a 16' lowboy An my Yamaha rhino 700 it just doesn't seem to have any power I lose speed going up hills any ideas
1992 4x4, 4” diamond eye exhaust, nv4500, he351cw
92cummins89
Re: Feels like I have no turbo
Postby laneends » Sun Jul 09, 2017 2:14 am
We are going to need a bit more info... do you have gauges? If so, what do they say? Does the trailer have brakes? If so, are they dragging?
1990 D-250 with getrag 360: pyro, boost, volt, oil pressure, fuel pressure, and water temp gauges, hot screw, 366 gov spring, THD pin, M&H dynamic timing spacer, throttle linkage adjusted for full travel, 4" turbo back exhaust, THD's LPPLP, BHAF, south bend clutch. THD 5x13 comps, 362sxe, 3" crossover, pump to the head
laneends
Postby 92cummins89 » Sun Jul 09, 2017 8:06 am
No boost gauges an there are no electric hook ups in the rear for a trailer
92cummins89
Postby Gots_a_sol » Sun Jul 09, 2017 9:31 am
What did you do with the wastegate?
-Joe
Gots_a_sol
Postby 92cummins89 » Sun Jul 09, 2017 11:15 am
Spring gated it
92cummins89
Postby Remps » Sun Jul 09, 2017 11:33 am
Boost making it to the afc?
Postby oldestof11 » Sun Jul 09, 2017 12:54 pm
Gonna need a boost gauge...
Postby 92cummins89 » Sun Jul 09, 2017 3:17 pm
Not sure if it is just doesn't seem to have any power
Is there a way to check it ?
I guess I need to invest in a boost gauge
92cummins89
Postby laneends » Wed May 30, 2018 12:41 am
Curious if you ever got to the bottom of this problem?
laneends
Postby 92cummins89 » Mon Jun 25, 2018 6:59 pm
Well I finally but a boost Gauge in An only pull like 6 lbs of boost any ideas
92cummins89
Postby fatty » Mon Jun 25, 2018 10:54 pm
Wire the wastegate shut and go for a drive. Report back with boost and egt numbers.
Postby PToombs » Tue Jun 26, 2018 5:49 pm
Either you aren't getting any fuel or the IC is leaking like a SOB. Does the truck smoke with the trailer? Did you install a pyro? (EGT gauge)
Postby 92cummins89 » Tue Jun 26, 2018 7:31 pm
Don’t have a pyro installed but my boost hasn’t changed any
92cummins89
Postby 92cummins89 » Tue Jun 26, 2018 7:33 pm
It doesn’t smoke to bad not like when I blew a ic boot on my duramax
It smokes but clears up when when I get moving
92cummins89
Postby PToombs » Wed Jun 27, 2018 4:45 pm
The slide pin in the pump top may be stuck also, not giving enough fuel to build boost. It's either that or a boost leak, bad IC, leak in the hose to the AFC, bad IC hose. You are either losing it or not making it.
Users browsing this forum: No registered users and 67 guests
