Feels like I have no turbo
Re: Feels like I have no turbo
Postby 92cummins89 » Wed Jun 27, 2018 8:32 pm
I have my gauge right under the grid heater
Should I tap into my hot ic piping?
1992 4x4, 4” diamond eye exhaust, nv4500, he351cw
92cummins89
Postby PToombs » Thu Jun 28, 2018 3:26 pm
Nope, should be good right there. Where are you located? Are you in an area that gets snow and they use a lot of salt or chemicals on the roads? I'm asking to get an idea if your intercooler may be rotted out.
Postby 92cummins89 » Thu Jun 28, 2018 7:32 pm
South Tx an 2 hrs from the coast
92cummins89
Postby 92cummins89 » Thu Jun 28, 2018 7:33 pm
Ima pull An I c boot off An see what happens
It’s like trying to build boost but can’t get over 8 psi
92cummins89
Postby 92cummins89 » Thu Jun 28, 2018 8:48 pm
There wasn’t anything special I needed to do when I took the electroncis for the waste hate was there ? I put the plug in there ?
92cummins89
Postby PToombs » Sat Jun 30, 2018 6:13 pm
Did that turbo have a small solenoid in it to run the wastegate? I think most people leave it in there. It's possible the gate is open and you are dumping thru that and not building boost. I've never messed with one, so not sure how it works.
Since you are located down there I wouldn't think the intercooler is rotted out, but it's possible.
Postby 79Powerwagon » Tue Jul 03, 2018 1:44 pm
There is a small port in the HE351cw compressor housing that leads from the wastegate solenoid back to atmosphere. You are likely loosing pressure there.
I brazed all the ports on my solenoid shut, could use JB weld, buy a plug, or put a set screw in that port.
https://www.ebay.com/i/322490620610?chn ... baffff3b66
79Powerwagon
Postby 79Powerwagon » Tue Jul 03, 2018 1:49 pm
79Powerwagon
Postby PToombs » Tue Jul 03, 2018 6:40 pm
Thanks for helping out, I haven't messed with any of those turbos yet!
