1979 Power Wagon CTD Build
Re: 1979 Power Wagon CTD Build
Postby erroljon » Mon May 07, 2018 1:35 am
Impressive build!
erroljon
Postby 79Powerwagon » Fri Jun 15, 2018 9:18 am
Bit more violent with a good converter :)
https://youtu.be/_4_hJfCUJig
79Powerwagon
Postby spencerdiesel » Wed Jun 20, 2018 3:15 am
I'll take it!
Postby 79Powerwagon » Fri Jul 20, 2018 5:03 am
Finally changed out the rotten factory intercooler for a 2nd gen unit. Opted to offset the cooler, which allowed me to use the driver side lower mount. Moved the pass side over a few inches, and used the 1st gen rubbers. Very minimal hacking compared to other mounting styles ive seen
79Powerwagon
Postby spencerdiesel » Sun Jul 22, 2018 7:36 pm
Slick looking and clean, what amount of egt reduction?
Postby 79Powerwagon » Mon Jul 23, 2018 4:57 am
Hard to give ya an accurate number since the factory cooler was leaking badly, but cruising egt down 50-100*
I was able to peg the 1600* autometer like nothing before, now havent seen the 1300* warning light come on but havent pushed it too hard.
Spoolup is much quicker and runs much cleaner
79Powerwagon
Postby 79Powerwagon » Mon Jul 23, 2018 5:06 pm
Changed the trans cooler setup, trimmed the lower valance and all fits like a glove.
79Powerwagon
Postby PToombs » Tue Jul 24, 2018 4:16 pm
That looks like a good setup. I think I would put a screen of some sort in front of it to protect it from rocks and stuff.
Postby 79Powerwagon » Tue Jul 24, 2018 6:36 pm
Thanks!
Was thinking the same. Have a piece of expanded metal that will work nicely
79Powerwagon
Postby PToombs » Wed Jul 25, 2018 5:25 pm
Yeah! I couldn't think of the name of it right then, expanded steel is what I was thinking of. 8)
Postby 79Powerwagon » Tue Sep 25, 2018 5:24 am
P7100 en route :oops:
79Powerwagon
Postby spencerdiesel » Wed Sep 26, 2018 6:41 pm
Balls.....
Postby 79Powerwagon » Fri Nov 09, 2018 6:15 am
Went to a 95’ D70 and a set of rancho 9ks. Its nice having functioning rear brakes :)
Benched 180 pump and another set of gold lines ;)
79Powerwagon
Postby 79Powerwagon » Fri Nov 30, 2018 12:51 pm
Ppump swap complete and a S472 addition
79Powerwagon
Postby spencerdiesel » Sun Dec 02, 2018 4:59 pm
Looking slick whered you set static timing at?
Users browsing this forum: No registered users and 120 guests
