Starter is stuck
Starter is stuck
Postby 92cummins89 » Sat Nov 24, 2018 2:30 pm
Changing the starter on my 92 Cummins an got all the bolts out an wires disconnected starter is lose but won’t come out any ideas?
1992 4x4, 4” diamond eye exhaust, nv4500, he351cw
92cummins89
Re: Starter is stuck
Postby 92cummins89 » Sun Nov 25, 2018 11:29 am
Anyone?
92cummins89
Postby PToombs » Sun Nov 25, 2018 5:30 pm
It should fall right out if all the bolts are out. Maybe the nosecone is broken and jammed in there?
Is it stuck on the breather tube? I remember on both my trucks the tube goes behind the starter and is jammed in there. It may be binding it somehow?
Postby monoblock » Tue Feb 26, 2019 9:28 am
Is it necessary to remove it ? Suggest a quick check of the solenoid contacts - known weak point
Also consider installing a relay. See my Post for links.
viewtopic.php?f=30&t=17858
Let us know ?
monoblock
Return to Electrical
