Never, never do this!
Postby mhuppertz » Fri Nov 30, 2007 6:06 pm
I learned to never put seal swelling type leak stoppers in a Cummins. They make the engine leak worse. My truck looks like it has the ebola virus!
MARK
'93 W250, HTT Stage IV/16cm, POD's, cut AFC pin, Pump advanced, Pyro, Boost, Fuel Pressure Gauges all non functional, burned wiring, 3/8” fuel line, BHAF on custom intake, 3,200 Spring, ARP Studs, New Head at 392K, Detroit Locker, NV4500, other stuff…
mhuppertz
Postby PToombs » Fri Nov 30, 2007 6:11 pm
Ahhhh, rust control system! ;)
Welcome to the "external lubrication club!" :lol:
Postby mhuppertz » Fri Nov 30, 2007 8:04 pm
PToombs wrote:Ahhhh, rust control system! ;)
Mizery loves company I guess ;)
MARK
mhuppertz
Postby PToombs » Sat Dec 01, 2007 2:23 pm
Then how come I'm lonely? :?
:lol: :lol:
Postby dodgetkboy78 » Mon Apr 07, 2008 9:29 pm
Huh, my truck stays dry............
unless you look underneath. :lol:
dodgetkboy78
Leaks
Postby gharger » Tue Apr 08, 2008 7:55 am
My CTD with 259k on it is amasingly leak free and is why I keep putting off checking the kdp fearing I may start a leak. :? Got to do it...I'm hoping when I actually start the job I can spot some sign of a replaced timing gear gasket or something.
'89 D350, autometer gauges, tweeked pump, stock sticks, 3200 spring, moded 727, pac brake
gharger
Re: Never, never do this!
Postby Mark Nixon » Fri May 01, 2009 3:02 pm
mhuppertz wrote:I learned to never put seal swelling type leak stoppers in a Cummins. They make the engine leak worse. My truck looks like it has the ebola virus!
Ever seen one that loaded the crankcase with diesel (ruptured lift pump diaphragm) and put it all out the crankcase vent?
Didn't realize it was happening (dark out) until oil pressure fluctuation told me something was up.
When daylight came the truck and trailer were HOSED down with the stuff!
I just changed oil, put on an electric pump and kept on trucking.
It got washed, eventually. :D
Postby cougar » Sun May 24, 2009 10:16 am
Dodges don't leak, they mark their territory.
92 W250 HD 47RH with Compushift. Upgraded H1C to 60/60/16, Scheid Lightning VE, 60# valve springs, DAP 7X.010 injectors, 4" DE exhaust.
01 2500 "the work truck".
cougar
Postby dieseljack » Wed Jun 03, 2009 6:22 am
No its rust control
1991 w250 rebuilt auto 170xxx Straight 4" turbo back dennyt stage2 fuel pin pump turned up 1/4 from bad new era 370s
dieseljack
Re:
Postby m880cummins » Sat Nov 19, 2011 3:02 pm
cougar wrote:Dodges don't leak, they mark their territory.
So true! My truck leaves a couple drips wherever it goes... Mainly from the transfer case seals/gaskets.
SUNY Maritime Class of 2017!
m880cummins
Postby dazedandconfused » Sat Nov 19, 2011 3:26 pm
My dam ps pump is leaking and the only noticable leak I see.
Postby Tsbourne09 » Fri Feb 24, 2012 11:22 pm
dazedandconfused wrote:My dam ps pump is leaking and the only noticable leak I see.
my ps pump used to pour out bad like a bottle of fluid every 2 days..... then it slowly stopped.... then i cleaned it and it started again..... diddnt clean it for a while and all the dirt the leaking fluid caught stopped the leaks....lol
Not On Yet: 60#VS
Tsbourne09
Postby kabob » Sat Aug 11, 2012 8:21 am
yeah my truck always lets everybody know that this is her spot LOL
kabob
Postby MicksJunkyard » Tue Dec 04, 2018 6:28 am
CANT STAND LEAKS! :shock:
1993 dodge d350 2wd/dual . Converted auto to NV4500. DIY air intake, fixed all the leaks and now ready to upgrade
MicksJunkyard
Return to Things you've learned
