1979 Power Wagon CTD Build
Re: 1979 Power Wagon CTD Build
Postby 79Powerwagon » Mon Dec 03, 2018 12:56 pm
Set to 21*. Seems pretty happy there. I did have to hook up the grid heaters as its grumpier to cold start than the VE.
Overall it runs so much nicer. And cleaner besides. The VE had a good run, but at 325k miles was pretty tired.
79Powerwagon
Postby spencerdiesel » Wed Dec 05, 2018 5:42 pm
Have you looked at afc live any? Are the 215 pumps the only ones that retard timing at higher revs?
Postby PToombs » Wed Dec 05, 2018 5:47 pm
21*? Really? I had my 97 set at 18, then dropped it to 14 to try to get better mileage. Which didn't work, btw. I saw no difference in the way it ran at either setting.
Postby spencerdiesel » Wed Dec 05, 2018 6:10 pm
No difference Pete? What alls done to your 97?
Postby PToombs » Thu Dec 06, 2018 5:34 pm
4k governor spring in it when I got it, a #10 little less fuel by Pete plate, then I had Eric flow hone the injectors to 40 horse. 4 inch downpipe to 5 inch all the way, and in summer I pull the pipe and put stacks on it. The thing runs ok, it's the god awful fuel mileage that's killing me. I expect a full size diesel truck to get 16ish around town, maybe 18-19 on the highway, summer fuel. This POS gets low 16 when I baby it, 13-14 average summer for any type of driving, and winter it's down to 11's
Postby spencerdiesel » Thu Dec 06, 2018 6:13 pm
Whats the truck weigh? 4.10 or 3.54, does your auto drag gears out? What stall?
Postby 79Powerwagon » Thu Dec 06, 2018 6:55 pm
spencerdiesel wrote:Have you looked at afc live any? Are the 215 pumps the only ones that retard timing at higher revs?
Yes i actually made my own before i sold my 2001 ppump truck. Found a local supplier of micro air pressure/flow regulators.
215 pumps at stock rack travel will retard. Set up right, past stock rack they can actually advance timing like 6*
Yeah 21*. It really screams up top, but that could just be me comparing it to a VE :lol:
79Powerwagon
Postby PToombs » Fri Dec 07, 2018 5:23 pm
spencerdiesel wrote:Whats the truck weigh? 4.10 or 3.54, does your auto drag gears out? What stall?
About 6k. 3.54, not really, doesn't seem like it. The trans is a new rebuilt that I bought. I didn't have time to do this one before I needed the truck due to weather so I got a trans from a local guy. Not sure I like the way it shifts either. Not sure on stall, better than stock. It didn't do well with the old trans either, I've been complaining about it for years.
Power Wagon, sorry about jacking the thread!
Postby spencerdiesel » Fri Dec 07, 2018 10:51 pm
Thats cool powerwagon, built not bought :)
Makes me curious Pete, I know P pumps take significantly more power to turn than VEs and are static (mostly?) timed. Thats just such a big difference from what most 12v guys seem to get.
At warm idle is there any smoke at all?
Your TC go into lockup alright? 6k is all kinds of light to get sub 15 mpg :|
Postby PToombs » Sat Dec 08, 2018 8:12 am
Not much smoke since I had the injectors done, it hazed bad before. It locks up fine, hits hard and locked!
Maybe more than 6k, 2500, ex-cab long bed. 7500? I don't actually know. I filled up this morning, with morning warm ups of 5 -10 minutes it got 12.5 last tank. Plus it was cut 1/3 with kerosene, which I know doesn't help.
Postby 79Powerwagon » Fri Dec 14, 2018 5:56 am
About ready to fire up
79Powerwagon
Postby PToombs » Fri Dec 14, 2018 6:11 pm
That looks nice!
Postby 79Powerwagon » Mon Jan 07, 2019 6:39 am
Taking it easy yet. Really happy with it though.
https://youtu.be/sc5_4cwAoD8
https://youtu.be/qD1nE8P9wqI
79Powerwagon
Postby 79Powerwagon » Mon Feb 18, 2019 8:37 am
Snow keeping it busy. Cant say that the 518 is liking the extra power :/
Trying to collect some parts for a 47rh build.
79Powerwagon
Postby spencerdiesel » Tue Feb 19, 2019 5:20 pm
Looking smexy are your 6x13s set to 245 bar?
