txs wrote:first thing is you need an auto 205 to do that swap, shouldnt be hard to swap that, most folks want to go the other way, auto to stick. You can use most of the 46 internals in the 518, clutches and so forth. The one the 46 probly dont have is the steel front carrier. You will need to find any four speed auto 4x4 overdrive assembly that used a governor, jeep cherokees got the re in 95, everything else went re in 96 (the re trannies dont have a hydraulic governor). Even an a500 OD unit will work for you, swap in the OD internals from the 2 wheel drive 518. If the 46re is lockup use the input shaft and reaction shaft support, and buy a 47rh valve body and make the 518 a lockup.
txs wrote:its your truck, do what you want, manual shift vb is big pain in the butt with column shifter or regular floor mount shifter. ive had experience with manual shifted autos back in the muscle car era, only one that was not a pain was the button shift mopars.
Users browsing this forum: No registered users and 101 guests
