Revmax ultra low stall converter
Postby 79Powerwagon » Tue Jan 16, 2018 4:49 am
Anyone used one?
Opinions?
Possibly Looking to upgrade the stock tc this yr.
https://revmaxconverters.com/product/a5 ... converter/
79Powerwagon
Re: Revmax ultra low stall converter
Postby dazedandconfused » Wed Jan 17, 2018 3:22 pm
I know a couple Duramax guys who run revmax stuff and love it. I don't know how this converter compares to others for our trucks though.
Postby 79Powerwagon » Fri Feb 02, 2018 8:38 am
Tried to get info from revmax and they couldnt tell me a damn thing about the converter they sell for a 518.
Ofelas hooked me up with a 89% TCS unit. Very excited to get it in.
79Powerwagon
Postby Remps » Sat Feb 03, 2018 9:28 am
40% less slip in the tc=40% more slip at the rear tires. :lol: That 351 should love that tighter tc. Are you changing the flexplate as well?
Postby 79Powerwagon » Sat Feb 03, 2018 10:19 am
Remps wrote:40% less slip in the tc=40% more slip at the rear tires. :lol: That 351 should love that tighter tc. Are you changing the flexplate as well?
Right!!
It was changed a couple years back, have one off a commonrail if need be.
Thinking I'm going to pull the engine and trans, reseal shifter rod, fresh rod/main bearings, hg, valve springs and headbolts
79Powerwagon
Postby Bersaglieri » Mon Mar 11, 2019 8:02 pm
I'm in for info/results. I have a buddy who's dad runs a 46RH in a 1993 truck. I tell him whenever I see him that a good converter would change that truck completely.
1997 Ram 2500 P7100 6BT - G56 - Dana
2002 Excursion VE 6BT- Allison - Sterling
Bersaglieri
Postby Begle1 » Tue Dec 17, 2019 1:10 am
How low of a stall speed is "ultra low stall speed"?
Where do we want stall speed to be around, 1500 rpm?
Postby BC847 » Tue Dec 17, 2019 6:50 pm
I've just retired a custom Suncoast that I ultimately had them set for around 1700. In hind-sight, I don't think I'd go that low again (increased turbo spool delay) but, it hooked well FWIW.
Postby fatty » Tue Dec 17, 2019 10:06 pm
BC847 wrote:I've just retired a custom Suncoast that I ultimately had them set for around 1700. In hind-sight, I don't think I'd go that low again (increased turbo spool delay) but, it hooked well FWIW.
That's the problem with non lockup converters in a turbo charged, rpm limited setup. More rpm makes the turbo(s) light faster but it also means you're getting out of the powerband sooner.
Postby dazedandconfused » Wed Dec 18, 2019 7:55 am
I have a Georend In my truck. It does okay and is the lowest stall he would build for it. If I did it all again I wouldn't have spent the money on the 518. I I really don't notice a big difference between it and my cheap reman converter that was In it.
Return to Transmission
