Fuel system leak!
Fuel system leak!
Postby VEfreak » Fri Apr 04, 2008 9:27 pm
I have a leak somewhere in my fuel heater system. Do i really even need a fuel heater, or can i just throw on an inline fuel water seperator and bypass the fuel heater?
VEfreak
Postby CumminsPride » Sat Apr 05, 2008 5:41 am
I would recommend it for driving/starting in 5* or below. I don't have one adn mine started at 10* but it didn't like it at all. I would recommend keeping it if it's cold there.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby cummins king » Sat Apr 05, 2008 8:47 am
mine starts fine with no gride heater and no fuel heater in -5 temps
93 4X4 auto
cummins king
Postby CumminsPride » Sat Apr 05, 2008 11:31 am
To be perfectly clear, I am speaking in "F" not "C". I don't know how your truck even fires at those temps CK. I have seen trucks stall here in below 0* temps driving down the road with no fuel heater. Now they may have been runnin summer fuel, I don't know.
CumminsPride
Fuel Heater Needed?
Postby Ace » Sat Apr 05, 2008 11:46 am
Unless you're driving alot in sub-zero temps I wouldn't keep it. They're more trouble than they're worth, IMHO. For one thing, the fuel passages in there where it connects to the manifold are a flow restriction. And of course those tiny little gaskets are a common problem. All it's going to do is possibly delay a gelled filter if you don't have an anti-gel additive in the fuel when you need it. If that's the case, it's probably just delaying the inevitable anyway.
I ditched the entire stock filter assembly including the heater. Drove it in single-digit temps several times right afterward, no prob.
