S-wrench (injection pump timing wrenches)
Postby SChandler » Tue Apr 08, 2008 10:42 am
Snap On has the 11-13mm combo s-shaped wrench for $34(http://buy1.snapon.com/catalog/item.asp?P65=&tool=hand&item_ID=4392&group_ID=551&store=snapon-store&dir=catalog). Sears lists a Gear Wrench brand ratcheting model on their website for $30 (http://www.sears.com/shc/s/p_10153_12605_00999771000P. Anybody know a better place to get them? Harbor Freight does not appear to be carrying them anymore. Also, Snap On lists under their Cummins service tools an injection pump wrench for the injection pump mounting bolts http://buy1.snapon.com/catalog/item.asp?P65=&tool=hand&item_ID=10652&group_ID=1288&store=snapon-store&dir=catalog. If I'm going to spend $30 on a wrench to get to the mounting bolts on the injection pump, I might as well get the one designed for it, right? I don't have any means to bend a cheap wrench into the appropriate shape so that is not an option. Thanks.
SChandler
Postby flashgordon » Tue Apr 08, 2008 2:52 pm
My snap-on wrench is NOT a combo wrench like that, but it work well on our pumps
Flash
flashgordon
Postby flashgordon » Tue Apr 08, 2008 2:58 pm
flashgordon wrote:My snap-on wrench is NOT a combo wrench like that, but it work well on our pumps
Heres a pic of it here.
http://www.dieseltruckresource.com/pics ... user=40988
Flash
flashgordon
Re: S-wrench (injection pump timing wrenches)
Postby bgilbert » Tue Apr 08, 2008 3:26 pm
SChandler wrote:If I'm going to spend $30 on a wrench to get to the mounting bolts on the injection pump, I might as well get the one designed for it, right?
Yes. Get the one you linked to, sp144. A must have for 1st genners.
Bill Gilbert
Postby cummins king » Tue Apr 08, 2008 3:28 pm
i have a 13 14mm snap on s bent wrench best 40 bucks i ever spent
93 4X4 auto
cummins king
Postby SChandler » Tue Apr 08, 2008 4:04 pm
Sounds good. Thanks for the input guys.
SChandler
Postby PToombs » Tue Apr 08, 2008 5:00 pm
You don't know anybody with a set of torches? I just used a cheapie wrench, hotted it up and bent it around. Best free tool I ever made! ;-)
Postby cummins king » Tue Apr 08, 2008 7:25 pm
i made 4 wrenchs like that (bending then with a tourch) but i kept on breaking them.... so i desided to go and buy a real one
93 4X4 auto
cummins king
Postby SChandler » Tue Apr 08, 2008 11:14 pm
PToombs wrote:You don't know anybody with a set of torches? I just used a cheapie wrench, hotted it up and bent it around. Best free tool I ever made! ;-)
About a year after I graduated from high school I had the chance to buy a complete torch/oxy-acetylene welding setup (including tanks) for $150. I didn't have the money so I passed it up. :mad: Does that count? Actually, I do know someone who has one or has access to one, however, I didn't think about it until just now and I ordered the Snap On wrench this afternoon. No biggie, it was $31.05 and ground shipping was free.
SChandler
Postby gomerpile » Fri Apr 11, 2008 2:26 pm
this is what $8 and some time got me.
alot better that $32 for a snap on
i should take it back and say the wrench bent :P :hs:
1992 Dodge D-250 LE auto, LSD w/3.54, about 200,000+ miles.Isspro Pyrometer , Sunpro tach,Tractor Supply Boost Gauge, Old Smokey Fuel Pin,4 turns on fun srew, starwheel turn CCW 1 turn, 40hp injectors, BHAF,16 cm housing.Sony Head Unit.
gomerpile
Postby PToombs » Fri Apr 11, 2008 3:39 pm
Mine is bent sharp where your "13" is, then gentle around.
Postby gomerpile » Fri Apr 11, 2008 5:59 pm
yeah that would have worked better than what i did, but i got the job done, just a few busted knuckels and a couple choice words got the job done :evil:
gomerpile
Postby cummins king » Fri Apr 11, 2008 7:47 pm
thats why i got a snap on my skin on my hands is worth more to me then 30 bucks,
that way i can keep it for other thing on the truck to ripe it off
93 4X4 auto
cummins king
Postby GO OVRIT » Sat Apr 12, 2008 6:13 am
If you keep your tool bill high enough, you never even notice small purchases like 32 bucks. :grin:
GO OVRIT
Postby dpuckett » Thu May 01, 2008 10:46 am
CK- that's why one uses tongs or pliers to hold the wrench when heating and bending.
I have an anvil and access to a set of torches. Actually, several torches. Getting a forge later this fall, after I gradiate.
Daniel
Return to Shop
