Engine build progress report #2
Postby Fnschlaud4620 » Wed Apr 09, 2008 10:44 pm
Hey, guys I just got the torgue plate done. I just thought I would show it off.
Sorry about the size, I havent figured that out yet
Later
Fnschlaud4620
Fnschlaud4620
Postby cummins king » Thu Apr 10, 2008 4:24 am
nice job no problem about the size mine are all to small and i cant figuare it out
joel
93 4X4 auto
cummins king
Postby CAJUN 93 » Thu Apr 10, 2008 6:15 am
i guess if i had the problem, i'de rather too large than too small :lol:
daryl
CAJUN 93
Postby swank » Thu Apr 10, 2008 7:48 am
WOW! That thing looks great! Good job.
truck
swank
Postby Begle1 » Thu Apr 10, 2008 1:13 pm
So what's the torque plate good for?
Postby CumminsPride » Thu Apr 10, 2008 1:17 pm
Explanation can be found in the shop section.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby PToombs » Thu Apr 10, 2008 4:58 pm
Boy! That looks a lot nicer than the last picture of it! :lol: Awesome piece of work. ;-)
Postby TWorline » Thu Apr 10, 2008 5:22 pm
Very nice job on the plate, that should do the trick! 8)
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby Fnschlaud4620 » Thu Apr 10, 2008 11:01 pm
He is some more pics of stuff I have been working on.
Balancing my my connecting rods
Some pics of my polished beems on the rods, this is used to relieve stress risers, Is it necessary? Cant hurt
These are the unblowable freeze plugs I made, I have $15.00 into them for alumunium stock, sure beats the $49.00 a piece ones that Hasilys sell
Here is my cam, I have drilled the end for a bolt on gear retainer, I still have to machine a retainer. It is a stock 24v core I have had it reground by Comp cams with a custom grind. Running the common rail lifters, this thing is going to rock!
Fnschlaud4620
Postby nooblet » Fri Apr 11, 2008 12:05 am
Thats awesome.
I have no idea what I'm looking at, but I'm sure its awesome 8)
Chris
nooblet
Postby TWorline » Fri Apr 11, 2008 7:40 pm
Are you going to produce the soft-plug replacements? That would be alot easier than collecting burnt out heaters! ;-)
Tim Worline
TWorline
Postby Fnschlaud4620 » Fri Apr 11, 2008 8:51 pm
I may make a few sets, they are real easy to make, just need a lathe.
I bet if you took your old heater to a local machine shop they could make a set of 5 for not much at all.
Fnschlaud4620
Postby seeker1056 » Fri Apr 11, 2008 9:11 pm
I am curious - i too used the 24v cam and drilled n tapped - but couldnt find a tool bit hard enough to open the cam gear for a slip fit
are you turning the cam down?
other issue is the key is way tooo small to hold much torque on the cam - how u dealin with that - new keyway and larger key?
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Fnschlaud4620 » Fri Apr 11, 2008 9:20 pm
I have an extra cam gear, I will be honing it out on a rod hone machine until I get a good slip fit on the cam, I will play around with the offset key way until I get the cam degreed in where I want it. Then I will install a normal gear, and press fit it on the end of the cam, using the keyway specs from the slip on gear. Then I'll use the bolt and retainer to keep it from walking off. It may be a degree +- from where I set it by swaping gears but I have looked at them and they are machined exactly the same.
Fnschlaud4620
Postby cummins king » Sat Apr 12, 2008 5:31 am
ken just take it to a machine shop they will have that kind of stuff
93 4X4 auto
cummins king
