I don't get it......
Postby eyoung429 » Wed Jan 24, 2007 12:38 pm
Just drill and tap or do I have to remove the manifold to weld a bung on it?? How thick are these manifolds?
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
Postby RumbleFish » Wed Jan 24, 2007 2:08 pm
Postby eyoung429 » Wed Jan 24, 2007 2:22 pm
Thanks Rumblefish....I will do that after I get home tonight...
eyoung429
Postby eyoung429 » Fri Jan 26, 2007 6:56 am
Okayyyy....
I went the safe route and pulled the turbo off to do the probe install....is the stock exhaust manifold supposed to be smooth inside?
I have moved the probe to the back port on the exhaust man. Pulled the fuel pin last night and wish I had my camera....that thing looks like a dowel with a very steep angle cut....aren't these things supposed to be shaped like a cone with one side off-set at the base?
decided to go and start looking at the tranny and it has B&M with a sn# engraved on the side of it!!! The torque convertor is yellow with black stripes on it.
Looks like someone didn't tell me what all was done to this!!
I will be making some phone calls this afternoon as I thought that I was buying a stock truck... :evil:
eyoung429
Postby Greenleaf » Fri Jan 26, 2007 7:42 am
The injector number you posted up must be a performance shop no. I think you wrote BD******** That does me no good.
The fuel cone is a custom unit. Possibly a Smoky or Dog unit.
No your understanding why your truck runs the way it does :)
Greenleaf
tech specialist/mod
Postby gman07 » Fri Jan 26, 2007 2:51 pm
Well if you really want, I could probably give you a stock pin in exchange for the custom one... I'd even be willing to trade you my stock injectors for your better... I mean, "less stock" ones :wink:
gman07
Postby eyoung429 » Fri Jan 26, 2007 2:59 pm
I am a little ticked off about this as I went and ordered a Dog pin, new bosch injectors, new turbo, intake, LP, extrude honed exhaust manifold and PAID for the stuff already...some of the stuff has been tweeked and I don't know if they will take them back...I could sell the stuff off my rig but I don't know how long it's been on there nor can I claim the condition other than by sight and "it was working fine when I pulled it off"
I thought I was starting with a stock truck and had a plan for it but now I need to concern myself with what all upgrades have been done and try and match where I want to go with it....
Called B&M and the tranny has upgraded clutches, hardened input shaft, Stage 2 transpak but they didn't match a converter with it. At least I know that the tranny will hold up to a bit more power...but don't know what kind of converter or stall it is.
eyoung429
Postby JLeonard » Sat Jan 27, 2007 4:38 am
My only experience with an aftermarket fuel pin was with one from DD, who I believe was the first one out....I borrowed one and gave it a try...
It was a real dog...my stock pin on the steep ramp was much, much better.
Your mileage may vary.
Jay
91 D250 w/modified Cummins, 89 D250 donor (future boat engine)
JLeonard
