GCWR
GCWR
Postby SChandler » Sat Jun 07, 2008 8:51 pm
Does anybody know what the GCWR is for these trucks? Specifically 5spd, 3/4 ton, reg. cab models with 3.54 gears :D . I have always wondered what it was. I know what the GVWR (8510lbs) is since it's on the tag on the door, but I've never seen the GCWR posted anywhere on the truck. TIA.
SChandler
18,000?
Postby Ace » Sun Jun 08, 2008 5:36 am
I recall seing somewhere it's around 10k more, depending on axle and gear. The DRWs and 4.10s are slightly higher. Can't recall where I saw that tho, so YMMV.
Postby PToombs » Sun Jun 08, 2008 5:34 pm
I found it in my owners manual.
D & W 250/350 5.9L
Rear Axle ratio___ 3.54 _____4.10
Man 5 speed ____16,000___ 17,000
Auto w/ o/d _____12,000 ___12,000
Maximum Allowable Tongue weights
D & W250_______GVWR_____Tongue
_________________All_______900
D & W 350
SRW_____________All_______1000
DRW_____________All_______1200
Postby SChandler » Mon Jun 09, 2008 8:13 am
Thanks Pete, I was hoping somebody with an Owner's Manual would look it up. I looked it up on TDR after I posted and found the 12,000lb. auto rating (which also made mention of a 14,000lb. rating with the under bed trans. cooler) and the 16k rating for the manuals. Interesting that the 4.10 gears get you an extra thousand pounds with the manual, but nothing with the automatics.
SChandler
Rear Gear Ratio
Postby Ace » Mon Jun 09, 2008 8:22 am
That's cause the rear gear don't make any difference with an automatic when it's sitting at a stoplight with 5 tons behind it. The clutch transmits alot more power to the rear from a standing stop, as opposed to the auto that transmits alot of heat into the torque converter.
Return to Things you've learned
