whats the deal???
Postby sdstriper » Sun Feb 04, 2007 6:13 pm
Greenleaf contacted me and cannot get a reply in here for some reason. I'll relay his comments on this one.
The following is a cut and paste of what Scott wrote; "I did not locate the given pump Bosch or Cummins pump number. I found his CPL and there is nothing there to indicate it used the given pump number(s)
The pump may work, however the governing may be different. Industrial used variable speed and automotive use a combination of variable and limiting speed governor. We need to know what the engine was removed from and the model year.
I don't know about installing the afc top. That may work out. It's the reverse lever that operates off of the tensioning lever. If the top of the tensioning lever is the same he will bo good there. The vent for the pump in on the AFC and the other pump he has will have a vent in a different location.
I have a "built from pump". However, its not just the last three pump numbers that are different. That is generally the rule. (First seven number must match) Mine is a 4 cylinder pump made into a six cylinder unit."
sdstriper
Postby Greenleaf » Mon Feb 05, 2007 10:01 am
92 D/UNIT wrote:152hp@ 2500
fuel rate 66.7 mm 3/stroke
This got me to thinking......so I checked my truck and it told me 160 HP @ 7.8mm/stroke :shock: So help me it does. So I thought I'd look at another and it's 190 HP @ 97mm3/stroke. No wonder my truck achieves such good economy. :?
I'm going to have to look into this again. Anyone have the tag available from another first gen engine? What is the fuel rate @ adv. HP/Speed?
Greenleaf
tech specialist/mod
Postby sdstriper » Mon Feb 05, 2007 11:09 am
Here's pump tag from mine.
Bosch Made in Germany
NR. 0 460 426 114
VE R 320
3916991
(011) 944 10887
sdstriper
Postby Greenleaf » Mon Feb 05, 2007 1:22 pm
No. I mean the engine tag. One on the timing case. I have your pump no.s memorized ....... It be the same as mine.
Greenleaf
tech specialist/mod
Postby DLittle » Mon Feb 05, 2007 1:43 pm
Mine's 1993 and the tag says
Fuel rate 74mm3/ stroke
160hp at 2500
Dana
1992 W250 auto, 290 k, stock for now SOLD
1973 W100 SWB, D70,D60, 5.9 Twin Turbo SOLD
1993 W250 193k, Auto, TOTALED 10/30/2009
DLittle
Postby sdstriper » Mon Feb 05, 2007 2:28 pm
Greenleaf wrote:No. I mean the engine tag. One on the timing case. I have your pump no.s memorized ....... It be the same as mine.
Heh heh... You work on buses I ride the short one...
sdstriper
Postby sdstriper » Mon Feb 05, 2007 2:29 pm
Where in the ? I cannot believe I never noticed that fuel rate in there before!!! ESN 44359804 with 78mm3/stroke, 160hp @2500.
sdstriper
Postby sdstriper » Mon Feb 05, 2007 3:13 pm
Upon closer inspection mine actually reads 78.0mm, yours was probably stamped late Friday afternoon or something...
sdstriper
Postby Greenleaf » Tue Feb 06, 2007 3:46 am
sdstriper wrote: yours was probably stamped late Friday afternoon or something...
:lol: Quite possible...LOL
Greenleaf
tech specialist/mod
Postby bgilbert » Tue Feb 06, 2007 2:04 pm
7.8mm per stroke. Well what is 7.8mm CUBED? IE 7.8 times itself three times??? :?: Who's got the calculator?? lol
Postby TWorline » Tue Feb 06, 2007 5:52 pm
Scott:
Mine reads 74 mm3 160hp@2500rpm.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby 92 D/UNIT » Tue Feb 06, 2007 8:20 pm
is the rate on the pumps not applicable once you start turning the screw?or is it something inside that changes the fuel rate? also mine says 74 but i think the pump has been replaced.
388/886
92 D/UNIT
Postby Greenleaf » Wed Feb 07, 2007 3:43 am
Right. Once you begin to alter the pump, the engine tag is null and void, save for the CPL and serial number. You change the CPL when you alter the injectors/turbo/swap injection pumps etc. etc. from OEM
The only thing you cannot change is the serial number, unless you build and engine from two or three units.
Greenleaf
tech specialist/mod
Postby CAJUN 93 » Wed Feb 07, 2007 1:27 pm
ok, not to side-track this but greenleaf whats up with the 4:00 am post'. thats way to early to be alert, let alone answer questions. your not one of those dang sick-minded morning people, are you :lol:
CAJUN 93
Postby dpuckett » Wed Feb 07, 2007 1:43 pm
He was probably still up doing research for us. :roll:
NonIC trucks CPL 804- 78mm/stroke 160hp@2500rpm
IC'd trucks CPL 1351 & 1579- 74mm/stroke 160hp@ 2500rpm
That IS cubic millimeters, i.e. 1/1000th of a cc/mL;
So, the cooler air and retarded timing made for the same power with an intercooler.
DP
