hard shifting
Postby dpuckett » Sun Oct 19, 2008 5:08 pm
Hydraulic clutch= no pedal slack. period. It's good you found the source of the slack. The bushings are a wear item, or should be considered so. Especially after 15 years.
It sounds to me like a clutch issue, or maybe just the hydraulics.
I'd get the whole shebang from Dodge. $350 is a big chunk of change, but it is pre bled- install the assembly and go on.
How far does your clutch fork move when the pedal is depressed? I have the Dakota this month, so I cant run out and measure mine.
Dainel
Postby PToombs » Tue Oct 21, 2008 5:26 pm
Ha! Wife doesn't like the new truck you bought her and stole the diesel huh? :lol:
Postby randyswelding » Wed Oct 22, 2008 5:46 pm
i havnt measured it,what do i need to measure :? im havin a brain fart today,im bout to buy a harley so my head is not on this planet still. :lol: is it the fork that depresses the clutch at the tranny side?and is there enough room to get a tape measure in there and how much play is too much
randyswelding
Postby mprmn08 » Thu Oct 23, 2008 9:52 am
u just use a tape measure and measure the pedal play until you can feel it moving the clutch off.
mprmn08
Postby randyswelding » Thu Oct 23, 2008 6:19 pm
ok cool and if any play in it is bad right?this weekend im tied up and workin to get so extra money to help pay for my new harley.ill measure some time this weekend thanks guys ill let yall know :D
randyswelding
Postby mprmn08 » Sun Oct 26, 2008 7:03 pm
no any play isnt bad. you want some play. a good rule of thumb if you dont have a spec for it is 1 inch. i would go with that and call it good.
mprmn08
Return to Transmission
