Buying first dodge diesel, need tips
Moderators: Greenleaf, BC847
Postby roy john » Tue Jan 06, 2009 1:27 pm
First of all, I can be a little clueless. PLEASE don't laugh at me! :oops: I have a few details of the truck i'm lookin at, but lookin at the prev forums, its not near all that i need! to my best knowledge its a 90, nonintercooled, 5 spd, 4x4. It hasn't been inspected since 01, and last started a few years prier to now. stuck a battery in an it fired right up! :D it came stock with single rear, he made it a duolly, and put a flat bed on it. at some point he replaced the trans. the new rear had a different ratio and ripped up the front. Just for starters i need 2 rears and a bed! :? he will take $500 for the truck! is this a good deal? it will be a daily driver but hope to make it a progect truck. and wat mods should i put on it for starters? thanks
roy john
Postby burnt_servo » Tue Jan 06, 2009 2:31 pm
is the body straight and rust free ?
'93 w250 .... stock ...
burnt_servo
Postby roy john » Tue Jan 06, 2009 2:38 pm
i thought didn't look to bad as far as rust. very good considering it sat for 7 years. not aware of any accidents in its history
roy john
Postby peobryant » Tue Jan 06, 2009 2:57 pm
$500 seems like a pretty good deal to me. If it is rust free, you should snatch it for $500.
1992 Dodge Ram W350, Cummins Turbo Diesel, G360
Postby roy john » Tue Jan 06, 2009 3:03 pm
how hard is it gonna be to find the rears and bed?
and what bolt ons would you recomend for starters
roy john
Postby peobryant » Tue Jan 06, 2009 3:31 pm
You want to make it back into a SRW? I have seen quite a few 3.54 geared rears on various classfields, so that shouldn't be a big problem. A bed in good condition may be a little difficult to find.
As far as upgrades, it all depends on what you want to do with the truck. But for sure, especially with a 5spd, you should get a 366 spring, and maybe look into either grinding the stock fuel pin, or get an aftermarket one.
If it has been sitting that long, I would change all the fluid before I did anything with it.
Re: Buying first dodge diesel, need tips
Postby MUDDY » Tue Jan 06, 2009 4:16 pm
roy john wrote:First of all, I can be a little clueless. PLEASE don't laugh at me! :oops: I have a few details of the truck i'm lookin at, but lookin at the prev forums, its not near all that i need! to my best knowledge its a 90, nonintercooled, 5 spd, 4x4. It hasn't been inspected since 01, and last started a few years prier to now. stuck a battery in an it fired right up! :D it came stock with single rear, he made it a duolly, and put a flat bed on it. at some point he replaced the trans. the new rear had a different ratio and ripped up the front. Just for starters i need 2 rears and a bed! :? he will take $500 for the truck! is this a good deal? it will be a daily driver but hope to make it a progect truck.
if ya want to mod your starter larry b has the beefier starter contacts. here is his website. http://www.fostertruck.com/
also welcome to 1st gen . org :grin:
ya might list your location. i know of good beds in idaho. perhaps would work out a trade for your bed. i also know of 60s and 70s if you are close enough.
sounds like a decent price. congrats.
93 D-350 dually
90 W-250
FOR IDAHO EVENTS WATCH
MUDDY
Postby Richie O » Tue Jan 06, 2009 4:19 pm
I think he meant what would be good bolt on upgrades for go fast stuff not the actual starter motor. :oops: :oops: :oops:
Postby roy john » Tue Jan 06, 2009 4:23 pm
yeah i want to get it back to original. some one suggested i look for a newer model bed. but didn't know what year they changed the style.
as for the pin, i took note that would be an option, as was a 3 pc, manifold. also smaller turbo housing, and deffinently injectors. but couldn't find any intake kits
roy john
Postby roy john » Tue Jan 06, 2009 4:35 pm
thanks Richie O :D yeah, I did mean (go fast bolt ons)
I'm located in Lancaster, PA
Thanks for the welcome, and the great help so far. :salut: I got lots to learn, but i love diesels, black smoke, and noise! esp the cummins sound :jumpsmile:
roy john
Postby Richie O » Tue Jan 06, 2009 4:40 pm
First thing first. Go buy the sucka. Then get ready to spend money. If it runs it is worth 500 bucks. It may be another thing if its worth fixin. I am doing a rebuild on a 93 that should have been thrown away. I did not want to strip it and part it out so I fixed it. Took lots of time but my spare time is free. 8)
Postby roy john » Tue Jan 06, 2009 4:44 pm
yeah it sounded almost to good to be true, esp when i put the battery in, and it started up like it was hot! :P
roy john
Postby PToombs » Tue Jan 06, 2009 6:19 pm
Yup, engine is worth 3 times what he wants for it. Get it now and worry about fixing after it's home. ;)
The beds are the same from '82 (or thereabouts) up to '93. Get it running 1st, and then worry about upgrading after. You might find that something is bad, like the turbo, (for example) so upgrade it when you replace it.
Postby roy john » Tue Jan 06, 2009 8:14 pm
Thanks guys, great tips :salut: 1 thing i didn't mention was that he also has a 91, intercooled, 2wd,5 spd that he took the bed off and extended it to a 11 ft flat bed, this one he also put a duolly rear on. this one only has 120,000 mi. 90 4x4 has 180,000.
for the 91 he wants $1000!
really want the 4x4 but then i didn't have the intercoolr. also wasn't real fond of shortin up the bed. :?
any words of wisdom? :P
roy john
Postby Richie O » Tue Jan 06, 2009 8:55 pm
Intercoolers are not that big of a deal. The non i/c trucks do well at stock to slightly bombed rigs. The non i/c will have more power then the intercooled truck if they are both stock.
Return to 1st Gen.org suggestions
