Rear gear oil
Rear gear oil
Postby Renigade » Sat Feb 07, 2009 3:15 pm
What weight of oil to go in the rear of my D250 93 year. How Much does it hold.
1993 1st gen BHAF -Smoke screw 2.5 turns, star wheel 2.5 turns. Fuel screw 1.25 turns, fuel pin ground.
Renigade
Postby gear jammer 91" » Sat Feb 07, 2009 4:02 pm
I put 80w-90w gear oil in mine. I don't buy ant particular brand, usually what ever is on sale. If I remember correctly it didn't hold more than a gallon when I did mine, also if you have a posi I think you need to put some kind of additive in it. I don't have a posi so I don't know.
01 LB7
gear jammer 91"
Postby Renigade » Sat Feb 07, 2009 6:21 pm
Thanks J ammer
Renigade
Postby PToombs » Sat Feb 07, 2009 6:24 pm
I use 85w-140. It's what we have at work. I haven't had problems yet. ;)
Postby Richie O » Sat Feb 07, 2009 6:29 pm
PToombs wrote:I use 85w-140. It's what we have at work. I haven't had problems yet. ;)
You mean its what WAS at work til it went into your truck. :lol:
Postby PToombs » Sat Feb 07, 2009 6:35 pm
Oh no! There's a whole pallet of pails left! :lol:
Postby Renigade » Sat Feb 07, 2009 6:56 pm
:D You two guys kill me. 8)
Renigade
Postby PToombs » Sat Feb 07, 2009 7:42 pm
Well, let us know when you're at deaths door and we'll stop. I don't wanna be responsible for offing somebody! ;)
:jumpsmile:
Postby Richie O » Sat Feb 07, 2009 8:16 pm
Well Pete, at least we have one fan. 8)
On subject I use 89w 90. Its what I have unless Pete came over. :roll:
Postby pulltilbroke » Sat Feb 07, 2009 8:44 pm
I'm runnin 85-140 Lucas gear lube in my D80
Postby SChandler » Sun Feb 08, 2009 12:39 am
I run Amsoil 75w-90 because my parents' next door neighbor is a dealer for them. The Amsoil recommendation is to run 75-90 unless you tow a lot of weight on a regular basis, in which case you should run the 75-140 (I think that is the grade for the heavier duty Amsoil stuff). The Dana 70 axle is supposed to take 3.5 quarts (7.0 pints) of oil and the Dana 60 (front) axle takes slightly less (about 3.25 quarts or 6.3 pints) according to the FSM for my 90.
SChandler
Postby burnt_servo » Sun Feb 08, 2009 4:52 am
this is slightly off topic here ... but ....
in my 1991 w-150 ..... before i got it , my dad had it for a good 10 years , and he would run penzoil 80 -140 gear oil in the diffs or something similar in that weight range .
last summer i changed all the fluids out , and in the diffs ran penzoil 75-90 ( because i had a 5 gallon pail of it for my vw's tranny ) .
anyways before this i would run around 480 to 520 km's per tank of propane .
with no other changes , it now easily runs to 600 km's per tank of propane .
something to think about anyway .
'93 w250 .... stock ...
burnt_servo
Postby Renigade » Sun Feb 08, 2009 5:18 am
Thanks guys for all your help here.
Servo I can understand how it would increase the milage. When I was a wee lad in my early 30's I use to rebuild my RTO 13 in my big truck and install nothing but mineral oil to make it shift better and roll with ease.
With this truck with no colder then we get here in mid tenn I most likely will use 85 - 90 because I'll be towing a 6000# travel trailer and up mtns at that. Love the info you can get off this site. My hat is off to yea guys.
Renigade
