Bright headlights=relay's+H4 conversions
Postby kiszka6911 » Fri Jan 12, 2007 1:37 pm
I just wanted to let everyone know that I finished installing my painless wiring headlight relay harness summit racing p/n PRF-30815 and the Autopal DOT H4 conversion lens with 60/55 white bulbs from ebay. I must say its quite a difference from the GE halogen's I had. The guy on ebay will take $26.00 for the H4 conversion lens & bulbs.
The relay harness is true plug and play with weatherpack fuse holder.
Doing a basic visual comparison. Installing one bulb at a time and then comparing each on and off the relay harness. Baseline bulbs are 3 Month old GE halogens.
GE Halogens on relay's are brighter then GE's on head light switch.
H4 conversions brighter on headlight swtich then GE's on relay's.
H4 conversions brightest on relay's
The quality of the Autopal H4 conversion lens are about 90% of the hella, (my buddy had a set of hellas) DOT H4 conversions. The polish of the reflector is just not as good on the Autopals but they were half the cost so I can live with that.
Anthony Kiszka. MI 1993 W350, 3.5" flowmaster exhaust, BD+60 injectors, OSFP, 3200 GS, westach BST & EGT. HTT Stage III, 16CM housing. BHAF, airflo elbows, Skyjacker springs, Buckstop bumpers, Firestone M/T 235-85-16 tires, PIAA fogs, H4 conversions.
kiszka6911
Postby sdstriper » Fri Jan 12, 2007 2:11 pm
I bet there is a huge improvement. With old skimpy wiring and an overloaded circuit this is on my list of to-do's, I have all the stuff except the conversion units.
sdstriper
Postby BEARKILLER » Thu Jan 18, 2007 9:21 pm
Can you post us a link to the E-Bay conversion lights??
Thanks.
BEARKILLER
Postby DLittle » Thu Jan 18, 2007 11:14 pm
Dana
1992 W250 auto, 290 k, stock for now SOLD
1973 W100 SWB, D70,D60, 5.9 Twin Turbo SOLD
1993 W250 193k, Auto, TOTALED 10/30/2009
DLittle
Postby kiszka6911 » Fri Jan 19, 2007 2:10 pm
Ebay Item number: 230079447311 for e-code's & item number: 330007065725 for the DOT.
I mad him an offer on the DOT's at $26 and he took it.
kiszka6911
Postby andyr354 » Mon Feb 12, 2007 1:39 pm
I just put a set of the E codes in my 91 Jeep Cherokee (same lights as a 1st gen uses) and they are great.
I got them with 55/100 bulbs. He will take a "best offer" of right around $22.95 for the pair.
http://stores.ebay.com/Autopal-Lights_2 ... idZ2QQtZkm
I really like the E ones more than DOT, you can run higher wattage bulbs and still have a nice low non glaring lowbeam pattern. Maybe someday the US will revise its old antiquated headlight laws.
I made my own harness and used 55/100 bulbs. I can EASILY see out 1/4 mile in front of me. That is as far as I could test on the hilly roads I have been on so far in the dark. The lowbeams were also much nicer than a DOT pattern in the fog this morning. The E style lowbeam has a sharp cutoff and doesn't glare.
I give it a thumbs up so far! Will have to order another set for my 1st gen.
93 W250, Getrag, 3.55 gears, BHAF, Fuel screw against lock collar, AFC set to deepest point, stock straight pipe, timing bumped 1/8", Isspro boost/pyro/tach, 220K+ miles.
andyr354
Postby Kinship » Fri Feb 23, 2007 7:26 am
Hello
can some one give me link or post a pic on wireing diagram to hook up this relay conversion set up ..
Kinship
smoke screw?
Postby kiszka6911 » Tue Feb 27, 2007 12:48 pm
If you buy the harness like I did its truly plug and play with two power leads to the battery.
kiszka6911
Postby dpuckett » Thu Mar 01, 2007 11:40 am
Ok is this link the same as the conversion kits, or will it work as one? Not trying to be cheap, but it IS a $5.95 per side deal, vs the $25 per side for the others. Brighter is better, and from the pics, it looks like the E style would be better than the DOT.
Daniel
Postby CAJUN 93 » Thu Mar 01, 2007 12:16 pm
looks to be the same seller. check out his shpping cost (25.00 :shock: ). gonna pay the same either way. but yes, those will work.
CAJUN 93
