I am going home for spring break to install my injectors and work on my truck.
I got the 7mm to 9mm adapters I needed from PPE for $25.00 which I thougt was a good deal, Piers lists them for $50.00 anyway what should the thickness of the washer be on these.
I have not measured them but I saw a post on TDR and Greenleaf was talking about .040 on PODS needing to be .020
Is there anything to be gained by placing the injectors in farther than .020? How thin is too thin?
I was thinking I could turn them thinner in our lathe but I am not sure about how much or if I am just wasting time.
I was told when I bought them they are at a 145 deg spray angle.
Thank you
Fnschlaud4620
