FUEL SHUTOFF SOLENOID PLUNGER
Postby TOMTOM » Sun Mar 04, 2007 6:35 pm
What are my options? I trimmed mine,after it quit today. is their a replacement? a fix? where is the best price on a new one if not?
TOMMY
93 CLUB CAB LE SHORT BED 209,000 MILES AUTO/OD 3.54 GEARS 4" TURBO BACK EX NO MUFFLER P7100 PUMP MODS B/D INJECTORS 13.55@99 MPH 440HP 967TQ ON #2 ONLY. PSD INTERCOOLER,BD SUPER B TURBO)47RE FULL MAN SUNCOAST TRIPLE DISC
TOMTOM
Postby 92 D/UNIT » Sun Mar 04, 2007 7:15 pm
when you said you trimmed it, did you trim it down to the center ring was visible on the plunger? diesel care products on ebay, here is a link.
http://cgi.ebay.com/ebaymotors/VW-Merce ... enameZWDVW
388/886
92 D/UNIT
Postby TOMTOM » Sun Mar 04, 2007 9:03 pm
Yup trimmed it with razor knife then cleaned it up with belt sander. Don't know how long it will last. Thanks for the link : BRIAN
TOMMY
TOMTOM
Postby JimmieD » Sun Mar 04, 2007 11:20 pm
Check out the link for the best prices on VE fuel solenoid. It's the same as the VW Golf diesel and Rabbit diesel parts listed:
http://www.autopartsauthority.com/oemma ... parts.html
JimmieD
Postby PToombs » Mon Mar 05, 2007 5:04 pm
I have a turned down one in mine, and Daledozer has another one. I had a buddy do them, he turned it in a lathe, used a drill bit for a tool. Then he touched it with a fine file. I have 3 or 4 k on mine, lots of WOT blasts, still works good. :D
Postby TOMTOM » Mon Apr 16, 2007 5:35 pm
Well got tired of tearing up plunger tips so i decided to fix mine. as follows:
ground off all rubber with wire wheel, pressed on a regular 1/4 20 nut on the little nail-head looking tip. Then mounted it in drill turning it down on a belt sander . Got it to the same shape as the rubber tip.
Installed today and it WORKS. Will keep yall updated, have taken picks but they came out blurred.
TOMMY
p.s. Would i get more fuel without a plunger? It seems to tear the tip when i have run it hard not when the pump is turned to max like its a restriction.
TOMTOM
Postby PToombs » Tue Apr 17, 2007 1:36 pm
It's interesting that it works with no rubber! :shock: I would think that it would let fuel thru enough to keep running.
Good job Tommy, keep us informed! :wink:
Postby mhuppertz » Tue Apr 24, 2007 1:42 pm
TOMTOM wrote:Well got tired of tearing up plunger tips so i decided to fix mine. as follows:
TOMMY
I can't quite visualize the nut part. Can you explain further?
mhuppertz
Postby TOMTOM » Tue Apr 24, 2007 6:05 pm
I ground the nut into a round tip that looks like the rubber tip. Thought about making a plunger out of solid steel but this seemed too easy.
So far it is working fine with the excption of hard starts. Seems i have to bump it over once then it starts right up. Will keep yall posted.
TOMMY
TOMTOM
Postby PToombs » Wed Apr 25, 2007 2:06 pm
I bet it's heavy enough that the solenoid can't pull it up. The lift pump helps push it open! :shock:
Postby mhuppertz » Wed Apr 25, 2007 4:57 pm
PToombs wrote:I bet it's heavy enough that the solenoid can't pull it up. The lift pump helps push it open! :shock:
Then how would it shut off???? :lol:
mhuppertz
Postby TOMTOM » Wed Apr 25, 2007 7:36 pm
It's spring loaded when you turn off the key the power is disconected and it shuts off. the solenoid is an electromagnet, very strong. i did not consider the weight being a big deal their is not mutch left of the nut after grinding. it's no bigger than the original rubber.
I'am by no means an engineer, just a lazy tight-wad. L-O-L
TOMMY
TOMTOM
Postby DALEDOZER » Thu Apr 26, 2007 2:51 pm
I have a turned down plunger as Pete stated and mine does not start like it used to, almost like the engine looses prime, or it does not pull up quite right.
1992 250 4X4, 5spd, HX40, 435s, 3200 gov. Snow Perf. Stg.2, 6" stacks, 4" skyjacker lift, 315 Yokahama Geolander M/Ts, borgenson shaft, piston LP, 7.3 intercooler.
DALEDOZER
Postby Fnschlaud4620 » Thu Apr 26, 2007 3:06 pm
Sorry for the dumb newbie post, but why are you guys doing this?
Thanks
Fnschlaud4620
Postby TOMTOM » Thu Apr 26, 2007 4:18 pm
High pump pressure from pump being turned up to max seems to blow a notch in the plunger tip. results in engine not shutting down when key is turned off.
TOMMY
TOMTOM
