6x.018?
6x.018?
Postby Dieselhick » Mon Mar 16, 2009 2:55 pm
Will a set of 6x.018s pass a snap test/smoke test on a stock set-up? Im thinkin of getting a set but I have to pass emissions. :(
1991.5 D250, Auto, 2wd
Dieselhick
Postby peobryant » Mon Mar 16, 2009 5:28 pm
I think Philip tows with his 6X.018's with stock pump setting (or close to it) but I don't know how bad they would smoke without a load, or how they smoke with a load for that matter. If he tows with them, I wouldn't think they would smoke that bad though...
Why don't you just keep the stockers in until after the emissions test?
Postby PToombs » Mon Mar 16, 2009 5:35 pm
Philips doesn't smoke because his converter never loads the engine enough to. ;)
Postby seeker1056 » Mon Mar 16, 2009 5:54 pm
setup for power they haze slightly drivin around but they will never pass a snap test unless you turn down the pump, starwheel etc before you go - I got through one last fall, but I think it was helpfull the guy liked pull trucks and it is a visual test.
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Philip » Mon Mar 16, 2009 8:49 pm
Just unhook your AFC boost line. It will not smoke no matter what you do. :D
Postby Dieselhick » Tue Mar 17, 2009 2:45 pm
I ask because my #6 injector is screwed and that cylinder knocks and it wont pass etest because of the white smoke. I eventually will be doing some performance modifications and was just wondering if I could go to the 6x.018s with the stock engine and have no problems.
Dieselhick
Postby Philip » Tue Mar 17, 2009 8:57 pm
Turn your fuel pin to a lower setting. Screw the smoke screw down. You would be suprised how clean you can run a set of 6x.018's.
On a cold engine look out. It will smoke. After the engine warms up. The exhaust will be pretty clear.
Postby Dieselhick » Wed Mar 18, 2009 4:35 am
Okay thanks alot, i think i'll give it a shot.
Dieselhick
Seeker
Postby Dieselhick » Wed Mar 18, 2009 6:57 am
Seeker I live about 45 minutes south of you and I was wondering where you got your 6x.018s from. Did you get them straight from a manufacturer or from a dealer here.
Dieselhick
Postby Begle1 » Wed Mar 18, 2009 12:22 pm
Philip wrote:Just unhook your AFC boost line. It will not smoke no matter what you do. :D
Seriously? I was trying to get my truck back down to stock no-smoke levels (which are totally no smoke at all), and I found it impossible. Blocking the AFC line did hardly anything. The only way I had to reduce smoke was backing off the power screw, but by the time I did that far enough to stop the smoke, the truck could hardly move my converter and I had to take it up to 3000 RPM in first or else the shift to second would stall it.
Is that not a normal experience?
Users browsing this forum: No registered users and 152 guests
