Thanks Bill....btw...here's one of yours from last year that I just found
Valve cover w/oil fill - 3928405
Oil drain plug washer - 3920773
Intake cover plate gasket - 3938152
Grid heater gasket - 3938158
Valve cover bolt o-ring - 3928406
Valve cover gasket - 3930906
Turbo oil drain gasket - 3937706
Exhaust manifold gasket - 3929881
Oil fill cap - 3901895
B Series tool kit - 3399869
Cummins screwdriver kit - 3400161
Non cycling thermostat - 3802968
Piston lift pump and parts needed for conversion:
- piston lift pump - 3936320 x1
- fuel line - 3914753 x1
- gasket - 3939258 x2
- spacer - 3914284 x1
- banjo bolt seals/washers - 3918191
Thermostat- Cummins ------------3802968
Thermostat housing (intercooled)- 3920353
Throttle rod (complete- i/c)-------4089076
front timing cover gasket----------3914385
Front main seal-------------------3804899
Cam follower gasket---------------3990732
Rear main seal=-------------------4089342
Vacuum Pump sseal kit (~$7.50)---4089742
Heater hose elbow (Gates)---------20388
Turbo oil supply line----------------3912747
Piston style lift pump (VE) ---------3936320
Fan hub assembly------------------3923004
fan hub bearing--------------------3910734
WIndshield Wiper bushings (HELP!)--49440
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
