hx-40
hx-40
Postby Cumminsdriver » Mon Apr 06, 2009 7:21 pm
How would a strait stock HX-40 W/18cm exhaust housing work for a mildly fueled automatic? By mildly fueled, I mean gov spring, full fuel screw short of runaway and the reverse foot gone.
93 W250extcab. Getrag, PODs,FASS Pump, tweaked IP
93 W250 ext cab. Auto.IP tweaks, FASS 95 gph w/filters.PODs. S300, ATS ex manifold. Goerend TC.
92 D350 reg cab.IP adjusted
76 F250 ext cab dually flat bed. 12 valve Cummins auto.
Cumminsdriver
Postby gear jammer 91" » Mon Apr 06, 2009 7:55 pm
I have been told the 18cm is a dog and hard to spool. I'm runnin a super hx-40, with my fuel setting's it spool's almost like stock. It has the 16cm housing on it.
01 LB7
gear jammer 91"
Postby ford69557ci » Mon Apr 06, 2009 8:20 pm
A little slow to spool without some injectors and dont let it got over 45-50 psi. The compressor wheels like to come apart after that.
ford69557ci
Postby Cumminsdriver » Mon Apr 06, 2009 9:07 pm
ford69557ci wrote:A little slow to spool without some injectors and dont let it got over 45-50 psi. The compressor wheels like to come apart after that.
Forgot to mention the POD's. Might go with some 370 tips. Does the spool still have issues with an auto?
Cumminsdriver
Postby Philip » Mon Apr 06, 2009 10:27 pm
That 18cm housing is the problem. A 16cm would work fine. The 18's are known for spooling slow without lots of fueling.
Postby cummins king » Tue Apr 07, 2009 4:50 am
I had no problem spooling my hx40 with an 18cm housing, with stock injectors. But you need to get the 8 blade version.
93 4X4 auto
cummins king
Postby ford69557ci » Tue Apr 07, 2009 2:28 pm
Yes even with the auto it will still be slow on the spool up. I would run a set of 370s over the pod's the 370's run cooler and cleaner.
ford69557ci
Postby cummins king » Tue Apr 07, 2009 6:13 pm
ford69557ci wrote:Yes even with the auto it will still be slow on the spool up. I would run a set of 370s over the pod's the 370's run cooler and cleaner.
it spooled better then my stock h1c 21 cm housing
93 4X4 auto
cummins king
Postby ford69557ci » Wed Apr 08, 2009 7:22 pm
Yeah the stock 21cm is a turd. They do work good on 5.0 mustangs though
ford69557ci
