Think I Have A Bad Injector
Postby RSWORDS » Thu Apr 23, 2009 6:59 am
Well I was out playing around in the 89. All was going well, went to take off and the truck started bucking and popping, first thought was... Well... the 50+ PSI finnaly got the head gasket, But then i noticed that teh smoke was black, not white or gray. Limped teh truck the 1/2 mile back to the house and noticed hat once the truck got some RPMs in it it ran OK, Turbo? Pulled it apart, nope all is good spins free and has no oil in it. If I get on the truck when it clears up I still get full boost. So after some thinking and talking with GO_OVRIT we are thinking an injector has some crud in it and is sticking open or not spraying right. If you but the truck in gear, hold teh brake and hit teh throttle it sounds like hammering sometimes, sometimes not... All teh fluids look fine.
Thoughts? Can I clean my injectors at home?
Oh and here is a little video. This truck would usually be smokeless or a slight haze at the hrottles I ran it at in this video. You can hear the engine spitting and sputtering
http://www.youtube.com/watch?v=stg7ptxq32s
RSWORDS
Postby Richie O » Thu Apr 23, 2009 9:39 am
Yes I heard it. :shock: Maybe the head gasket blew between 2 cylinders and is allowing compression between the 2. It sure sounds bad. :evil:
Postby RSWORDS » Thu Apr 23, 2009 10:15 am
Yeah thats the other thought...
Would it have exxcess black smoke like that w/ a head gasket?
RSWORDS
Postby Richie O » Thu Apr 23, 2009 10:20 am
Don't know, Never blown one yet. Notice I say YET. :lol:
Postby RSWORDS » Thu Apr 23, 2009 10:35 am
Richie O wrote:Don't know, Never blown one yet. Notice I say YET. :lol:
same boat I was in. Cant say I didnt see it coming!
Oh well... Any Ideas On cleaning teh injectors? I have to pull them anyway to pull the head so I might as well clean em up.
RSWORDS
Postby bgilbert » Thu Apr 23, 2009 1:50 pm
Crack each injector one by one and listen for a difference in sound between each cylinder.
Bill Gilbert
Postby RSWORDS » Thu Apr 23, 2009 2:14 pm
bgilbert wrote:Crack each injector one by one and listen for a difference in sound between each cylinder.
Did it Bill... Ran like crap either way, some when I lossened it made it worse than others but the all made it run worse. #6 was teh biggest change... What you think? Worth pulling them and cleaning or should I just order my gasket?
RSWORDS
Postby oldcool90 » Fri Apr 24, 2009 4:30 am
What kind of injector you runing,iv'e seen some after market injector tip crack and make trucks run like that.I would pull them first,and maby do a compresion test on the engine.
oldcool90
Postby RSWORDS » Fri Apr 24, 2009 8:56 am
Pulled all the injesctors out this morning, cyl 2 and 3 had LOTS of soot buildup on the tips, the others looked clean except for #5 that had a little soot on it. This the soot on 2 and 3 is from incomplete combustion from a blown gasket between the two? All 6 injectors are soaking in stanadyne right now. I thinking about pulling teh nozzles off when I get home tonight and cleaning them with a soft brush.
RSWORDS
Postby RSWORDS » Fri Apr 24, 2009 10:02 am
Think I should go ahead and get the gasket on the way?
RSWORDS
Postby bgilbert » Fri Apr 24, 2009 1:10 pm
Soot is usually common for 'hot' trucks' injectors. Especially with POD's. I'd do a compression test before pulling the head. A cheap Harbor Freight diesel engine compression tester along with a B Series Cummins compression adaptor, I have one from Matco, around $35, will be needed as it's not included in the HF kit. It's worth having both in your Dodge Cummins tool selection. I don't have any 7mm injector cores or I'd let you try them. I'll have your 9mm's available in about a month, but that doesn't help you now.
Postby RSWORDS » Fri Apr 24, 2009 1:38 pm
If teh gasket is blown between two cyl it should show low in both of them right?
RSWORDS
Postby dpuckett » Mon Apr 27, 2009 10:48 am
RSWORDS- yes, compression would be low, or leak down between the two blown cylinders.
Judging by the sound in the video, I'd suspect some fuel issues, either pump or injectors. It has a definite miss. Take the sticks to an injection shop and have them pop tested. That should be no charge.
Dan
Postby RSWORDS » Mon Apr 27, 2009 1:07 pm
Well Did the compression check...
#1 - Fine
#2 - Fine
#3 - Fine
#4 - None... Zero
#5 - None... Zero
#6 - Fine
Also when cranking it it make sthis real odd suction/backfire but not a pop
RSWORDS
Postby RSWORDS » Mon Apr 27, 2009 1:41 pm
Guess its a good thing this showed up today!
RSWORDS
