Factory Tach In A '91.5
Postby peobryant » Thu May 07, 2009 7:54 pm
I know I have asked this before, and didn't get a real answer.
How can you hook a factory tach up into a truck with no crank position sensor? I know it can be done, as I have seen a factrory tach on a Non I/C truck.
Would I be able to use a wiring kit from Isspro?
I E-mailed Isspro about this a couple minutes ago, but I may call tomorrow and talk to someone.
Richie, what was the name of the guy who took care of you? Have the number by chance?
Thanks
Postby Richie O » Thu May 07, 2009 8:07 pm
Just call Isspro and ask for tech department. His name is Don . Don't remember his last name.
Postby peobryant » Thu May 07, 2009 8:10 pm
Well, Isspro just E-Mailed me back, and told me to speak with Don in the tech. department. :D
If I can't get it to work, I'm sure I can sell it for more than I bought it for. :roll:
Postby wjones » Fri May 08, 2009 2:39 am
Isspro has a magnetic pickup kit PN: R8912. hook one wire to the sensor feed on the tach and the other to the ground and it should work. You can get the kit from genos but your looking at about $60 last time i checked.
1992 W250, nv4500 Club Cab
wjones
Postby RumbleFish » Fri May 08, 2009 5:04 am
my n/i 91 had a factory tach. it had a factory crank sensor and harness. and my sliding rear window wasnt missing any parts.
Postby peobryant » Fri May 08, 2009 11:37 am
RumbleFish wrote:my n/i 91 had a factory tach. it had a factory crank sensor and harness. and my sliding rear window wasnt missing any parts.
My slding rear window wasn't missing any parts either. Until my girlfrined messed with it.
On our first date, as I was taking her home, my headlight switch went out. There must be something about her...
Postby RumbleFish » Fri May 08, 2009 12:37 pm
well if you woulda had her home before dark...or the next morning...you wouldnt have had to worry about it.
i hear ya tho. when i had my ramcharger, i replaced alot of bad/broken stuff and it was working great for a long time. my now wife said something was gonna break on it soon. on my way home the wiper motor went out...in a heavy downpour. oh well, i blamed her and got some action for her guilt. it all worked out fine.
Postby rmauto1 » Mon Dec 07, 2009 6:34 pm
RumbleFish wrote:well if you woulda had her home before dark...or the next morning...you wouldnt have had to worry about it.
It's pretty sad when you have to break your truck to get some "action". ;)
rmauto1
Postby PToombs » Mon Dec 07, 2009 6:44 pm
If you met Jeff it'd be pretty obvious why. ;)
:jumpsmile:
Postby rmauto1 » Mon Dec 07, 2009 7:09 pm
Not to pirate this post, but what is the story with the factory tach?
Is it actually built into the cluster, where the fuel gage normally is? Or is it the small tach on top of the dash that I have seen so many pics of?
rmauto1
Postby 921stgen » Mon Dec 07, 2009 7:40 pm
It was a dealer install option I believe, and most of the time they are on the dash. Like this one.
http://www.dieseltruckresource.com/dev/ ... ctory+tach
91 W250 pods, , pull cable, Isspro FP gauge, Isspro boost, pyro, 366 spring, 91 W350, sold-92 W250, 40 hp Injectors, Bully Dog Fuel Pin, Isspro-tach, boots, pyro, AM electric fp gauge, 3200 GS, 5" AEM intake, 4" exhaust 5" stack
921stgen
Postby rmauto1 » Mon Dec 07, 2009 7:49 pm
921stgen wrote:It was a dealer install option I believe, and most of the time they are on the dash. Like this one.
Thanks for the reply! Thats what I always thought it was, but as I was reading this post, I thought it might be an in dash unit like the new trucks. Thanks for setting me straight on that one.
rmauto1
Return to Electrical
Users browsing this forum: No registered users and 73 guests
