RumbleFish wrote:eaton
KTA wrote:Will the 14 bolt ring and pinions work? If not what kind of gear ratios are available?
pulltilbroke wrote:The beauty of this axle is its out of 3/4 and 1 ton trucks so we'll still be able to pull at any hook this axle has some serios beef, Its got a lot of advantages over a 70 and even an 80, 2" pinion, 3 pinion bearings, pinion support, and a load bolt to resist ring gear deflection, Think Semi truck hardware for a pickup
txs your gettin warmer
Any more guesses
