Antifreeze
Antifreeze
Postby whereswaldo250 » Sat Mar 31, 2007 8:11 am
What kind of antifreeze are you guys using?
1992 Dodge W250 standard cab STRAIGHT PIPED! black 3/4 ton Cummins Turbo Diesel Intercooled, 4x4,148000k, getrag 5 speed, np205 transfercase with PTO, D60 in the front, D70 in the rear posi (4:10 gears), Mods soon to come
whereswaldo250
Postby Fnschlaud4620 » Sat Mar 31, 2007 10:30 am
I use John Deere cool-gard, 50/50 premix
I also use Deere plus-50 engine oil
must be a farmer thing, we run 15-40 deere oil in everything gas or diesel.
fnschlaud4620
Fnschlaud4620
Postby gman07 » Sat Mar 31, 2007 11:08 am
Fnschlaud4620 wrote:I use John Deere cool-gard, 50/50 premix
fnschlaud4620
Same here, we ran Case 15-40 in everything until we got our 2004 Infiniti G35x; we use synthetic in it.
gman07
Postby whereswaldo250 » Sat Mar 31, 2007 11:34 am
Is there a certain kind of antifreeze for diesels? I need to get some today and a checker or Autozone.
Thanks
WW
whereswaldo250
Postby Fnschlaud4620 » Sat Mar 31, 2007 12:30 pm
anti-freeze is anti-freeze as long as it is new and clean and mixed at the proper ratio any will do.
Fnschlaud4620
Postby Begle1 » Sat Mar 31, 2007 2:55 pm
Anti-freeze is not just anti-freeze. There's dozens of sorts on the market.
The standard color for pre-2001 Chrysler vehicles is green. That's what all the first gens come with. It's got to be changed every 30,000 miles or 2 years to prevent corrosion.
Now all the companies use their own color of crap.
The OAT/ HOAT fluids are Orange for GM DexCool, Pink for Audi/ Volkswagon and Toyota, Dark Green for Honda, Caterpillar uses Red, Orange for Daimler/ Chrysler/ Mercedes, Fuschia for Saturn, Yellow for Ford. Then there's blue stuff for other European and Korean companies. I think that all of the off-colored stuff is good for 150,000 miles or 5 years.
Then there's the aftermarket stuff that you buy by the gallon that can be amber, light green or whatever color you can imagine. I think Prestone's new stuff is plaid and Peak's is polka dotted.
Some colors are compatible with others, some anti-freezes are only good in certain engines or radiators, some compatibilities aren't valid for given vehicles.
It would probably be worth it to put some of the newer stuff in your truck, just for convenience; I sure don't know enough to say which colors would be okay though. For what it's worth, Chrysler says not to do it. But there's always a chance that the previous owner filled his system up at whatever dealer his cousin worked at.
Postby RumbleFish » Sat Mar 31, 2007 7:27 pm
Most of the big antifreeze brands make now make a coolant that is compatible with anything. That means you can buy a gallon and use it to top off both anything form an 05 Chrysler to a 78 Ford.
I would use a coolant that is compatible with anything, but stay away from Dexcool.
Postby PToombs » Sun Apr 01, 2007 6:47 am
Don't forget to add the additive for diesels. Helps prevent cavitation! I can't remember what it's callled. :roll:
Postby holeshotracing » Sun Apr 01, 2007 2:35 pm
I thought Cummins doesn't recommend any coolant additive? I also thought cavitation only matters in a wet-liner engine, because it causes the sleeves to get pitted? Please correct me if I'm wrong.
Black 1993 regular cab W250, G-trag, NP205, 262K, muffler gone, Isspro tach & boost
holeshotracing
Postby bgilbert » Sun Apr 01, 2007 11:17 pm
Two types, ethylene glycol based antifreeze and proplyene glycol based antifreeze. You want to use ethlyene glycol based antifreeze, not the other one. Just pick up any jug of AF and read the fine print.
Bill Gilbert
Postby JLeonard » Mon Apr 02, 2007 6:34 am
No, you are correct. Parent bore engines don't suffer from cavitation.
91 D250 w/modified Cummins, 89 D250 donor (future boat engine)
JLeonard
Postby PToombs » Mon Apr 02, 2007 1:54 pm
Another myth proven wrong! :shock: Boy! You'd think I'd be used to that by now. :wink:
I hope it helps, I put it in mine. :oops:
Postby whereswaldo250 » Tue Apr 03, 2007 5:35 pm
I talked with a mechanic from the dodge dealer and he said that the first gens did not have a cavitation problem mostly the ford diesels did.
whereswaldo250
