Bottom Tapping
Bottom Tapping
Postby MrHorsepower » Fri Jun 19, 2009 10:22 am
Hi all,
I am installing head studs and I was curious if you bottom tap all holes or just the 6 that go under the valve cover?
Thanks,
Bob
In Progress: '84 Chevy Silverado dually w/19.5 rims.
1st gen, New Eras, s300, 366, DennyT, piston LP, Pacbrake, 60lbs. springs, ARP studs, Snow Perf. stage II, '97 DR IC, 4" stacks.
NV4500, 14 Bolt Locker & Dana 60 Posi w/3.73's
MrHorsepower
Postby Philip » Fri Jun 19, 2009 2:44 pm
Do all of theml.
Postby SNOOT » Fri Jun 19, 2009 2:50 pm
What he said builds muscles... Have fun..
1993 W350
SNOOT
Postby Philip » Fri Jun 19, 2009 4:14 pm
A cordless drill on a low torque setting. Why build muscles. :lol:
Postby PToombs » Fri Jun 19, 2009 5:44 pm
I try to bottom tap every hole I do. Doesn't always work out real well though. :D
Postby jensenkennels » Fri Jun 19, 2009 7:57 pm
PToombs wrote:I try to bottom tap every hole I do. Doesn't always work out real well though. :D
Oooh......I see what you said there. :roll:
jensenkennels
Postby TWorline » Fri Jun 19, 2009 9:15 pm
Kinda sounds like you need a longer tap Pete. ;)
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby PToombs » Sat Jun 20, 2009 6:21 pm
That's what she said! :shock:
Postby MrHorsepower » Sun Jun 21, 2009 6:30 pm
Thanks for the info guys, a little too much info from Pete...
so here is the next question. I bottom tapped the holes, but i had to loosen the studs back up, becuase the nut would not go onto every thread if you didn't. Next, my mills at school are down due to a shorted circuit. I did not mill the tops of the rocker pedistals. If I do not use the washer under the nut it will clear the valve cover, if I do it hits. So is it ok to use the studs without the washers on the pedistals until my $900 breaker comes in? Then I will mill the vavlecovers to clear the nut and washer, it just touches the webbing.
Any thoughts.
Thanks,
Bob
MrHorsepower
Postby TWorline » Sun Jun 21, 2009 8:05 pm
You could go in there with a die grinder and a round burr to take that webbing down or use a right angle if you have it.
Tim Worline
TWorline
Postby SNOOT » Sun Jun 21, 2009 9:14 pm
If it were me I would mill the rocker pedestals but thats me.. It makes things fit real nice..
1993 W350
SNOOT
Postby skilletky » Mon Jun 22, 2009 12:13 pm
how much metal do you need to mill off?
skilletky
Postby mprmn08 » Mon Jun 22, 2009 3:46 pm
.200 deep by 1.1 wide as per arp instructions. i just got my new studs on thursday and am waiting for time to mill mine and resurface and fire ring the head.
mprmn08
Postby SNOOT » Mon Jun 22, 2009 3:52 pm
If you send them to me I would be happy to mill them for FREE!! but you would have to pay for shipping...
1993 W350
SNOOT
Postby soggy » Mon Jun 22, 2009 5:21 pm
Where would I find the tap needed to do this? And what thread size and pitch?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
