Cam and misc mods...
Postby SNOOT » Sun Jun 21, 2009 9:23 pm
Well I went to the track over the weekend with some good results. Last year I ran a best of 15.65 in the 1/4 79MPH.
I did a o-ring job, cam and some special valve springs. Put it all back together and left the fuel right were I had it last year. We also put the thiker head gasket in lowering the compression a bit.
Diesel pros did the cam, head work and valves I did the install.
I ran a 15.05 in the 1/4 @ 88mph. For the most part this was all the cams work as I did not add any additional fuel.
I am running into a drive pressure issue now as soon as I get it worked out this thing is going to kick but.
Very excited..
1993 W350
SNOOT
Postby gear jammer 91" » Sun Jun 21, 2009 10:28 pm
Good times! I can't wait to see what you can do once you get your drive pressure issue's figured out and add some more fuel.
01 LB7
gear jammer 91"
Postby SNOOT » Mon Jun 22, 2009 9:06 am
OH and I won the event!!
:D
1993 W350
SNOOT
Postby KTA » Mon Jun 22, 2009 10:40 am
That is one hell of a trophy!!! Congrats on the accomplishment!
Return to Competition
Users browsing this forum: No registered users and 78 guests
