My new puller motor build
Postby seeker1056 » Wed Jun 24, 2009 7:04 pm
Well we were goin to Bolton till about ten minutes ago - I guess second gear didnt like all the new hp we have
Man what a ride, and I am not kidding super super LOUD - we have to wear earplugs in the cab
So this things builds boost almost instantly, and we have it externally wastegated to 50 psi now.
Totally amazing how this thing runs
Interestingly enough boost is almost 20 psi before drive pressure starts to come on, and doesnt catch up to 1:1 untill about 45 psi and stays at 1:1 as far as I could tell - even with two of us in the cab and watchin the guages its a chore to keep track of what all is goin on, drive pressure, fuel pressure, egt, rpm , boost, oil pressure, trans temp,
Cant wait to get this thing on the track
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Crazy Matt » Mon Jun 29, 2009 10:42 pm
How much head work is done to ur truck?
'90 cummins, mod'd 727,converter ,4" from dp back, 16cm,ported exhaust housing/ats manifold, gds 60mm upgrade, 366, dennyt pin, .Ported head, camshaft. In the process of resetting injector pop pressures and put the whole mess back in the truck.
Crazy Matt
Postby seeker1056 » Tue Jun 30, 2009 4:02 am
mmmmm - LOTs - lol
bigger valves, ported, shaved, ported exhaust manifold, and ported T3 /HX50 turbo adaptor
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Crazy Matt » Tue Jun 30, 2009 7:30 am
Any of the ports/ bowls that ur willing to give up?
Im trying to get a good idea on what mine should look like when Im done. I dont like what im finding on the net for pics so far.
Crazy Matt
Postby seeker1056 » Tue Jun 30, 2009 8:55 am
sorry I didnt take any photos of my porting
Most porting tends to be proprietary, and the photos you see are home grown, and not necessarily any good on a turbo head.
Large and pretty isnt always a good thing
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby bgilbert » Tue Jun 30, 2009 12:47 pm
seeker1056 wrote:mmmmm - LOTs - lol
What did you come up with on the bigger valves?
Bill Gilbert
Postby seeker1056 » Tue Jun 30, 2009 12:59 pm
well you have one of two inexpensive choices depending on what you wish to do
I used cummins intake valves all across the board
Next step up when i refresh the head this winter will be 351 windsor intake and exhaust valves, springs, retainers etc with a lash cap - makes the stack exactly the right length, and the vlave guide will ream easily to the requried size
One can go as large as 1.8 exhaust, and 2.2 on the intake from what I have been able to find out. However that is on the extreme side as you are terribly close to the cylinder, and valve shrouding becomes an issue as well
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby IowaCummins » Tue Jun 30, 2009 9:46 pm
i wanna see sone vids of this beast!
IowaCummins
Postby RumbleFish » Wed Jul 01, 2009 7:11 am
holy crap thats a big avatar
Postby KTA » Wed Jul 01, 2009 8:50 am
Using intake valves in the exhaust isn't a very good practice for long because they aren't made to take the heat. It is probably a good thing this is a puller motor not a street motor.
Postby seeker1056 » Wed Jul 01, 2009 8:54 am
i had the same reservations - but PDR has been doin this intake/exhaust valve thing for years
I will be switchin to the Ford valves this winter as this is gonna be an ongoin all out VE assault in the Pro Street class.
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby seeker1056 » Thu Jul 23, 2009 1:07 pm
http://s125.photobucket.com/albums/p76/seeker1056/
pix of the new truck before paint
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Richie O » Thu Jul 23, 2009 1:10 pm
I really like that scoop. :D It sure gives me ideas. 8)
Postby 93_Fummins » Thu Jul 23, 2009 2:01 pm
Lookin good!!! :thumleft:
93_Fummins
Postby mprmn08 » Thu Jul 23, 2009 4:41 pm
has any one got good flow numbers with the bigger exhaust valves? i ask cause we put int. valves on the exh side on a head at work and didnt gain anything. we actually lost some flow. now we didnt do a full port job on it but we did blend the pockets at least. i just ask cause i dont wanna see someone try it and go backwards. i dont know if it was gettin valve shroudin bad or what but just a thought.
mprmn08
