another injector question
Postby bulltamer » Wed Jul 01, 2009 9:42 pm
What injectors should i get for daily driving. PODs?
stock '92 d350, auto, extended cab, 9 LEDs on each side, straight piped
coming soon: clear tail lights, fender lights, tailgate lights and clear second gen. cab lights
bulltamer
Postby skilletky » Thu Jul 02, 2009 4:10 am
it depends. what does your daily driving consist of? what are your future plans for the truck? is fuel mileage a concern?
skilletky
Postby peobryant » Thu Jul 02, 2009 6:00 am
Get some 6X.016's and be done with it. 8)
Postby apwatson50 » Thu Jul 02, 2009 8:38 am
'91 Cummins wrote:Get some 6X.016's and be done with it. 8)
What if you don't want any idle/low throttle hazing?
92 Cummins, 4x4, 270K miles
apwatson50
Postby Richie O » Thu Jul 02, 2009 9:06 am
6X16s are good for power but as said above they are hazy.
Postby bulltamer » Thu Jul 02, 2009 9:58 am
my daily driving conists of goin to school and riding around
fuel economy is not a concern
bulltamer
Postby RSWORDS » Thu Jul 02, 2009 12:11 pm
I dont think 6x16's are a DD injector. I know I would not want to do it.
Now a DD/Street Terror yes they would be nice!
RSWORDS
Postby Richie O » Thu Jul 02, 2009 7:02 pm
RSWORDS wrote:I dont think 6x16's are a DD injector. I know I would not want to do it.
They can be SMOKEY can't they Bobby? :D
Postby bulltamer » Thu Jul 02, 2009 7:10 pm
so PODs will be a good daily driver injector
can i run PODs with stock pump settings or do i have to crank up the pump
bulltamer
Re: another injector question
Postby Richie O » Thu Jul 02, 2009 7:16 pm
bulltamer wrote:so PODs will be a good daily driver injector
Will work with stock settings. You really need to advance the timing. They have a higher pop pressure then stock so If you don't advance the timing it acts retarded. I don't like them just because I feel it makes the pump work harder due to pop pressure being higher. It may not effect the pump but it is on my mind. 8) They can be a poor milage injector as well as hazy and dirty.
Postby bulltamer » Thu Jul 02, 2009 8:38 pm
i want sum injectors that make sum good power without breakin the bank
bulltamer
Postby peobryant » Thu Jul 02, 2009 9:55 pm
bulltamer wrote:i want sum injectors that make sum good power without breakin the bank
POD's can be had for around $440 new, and even less used. They are dirty, smokey and hot, so if you don't mind that, then go for it.
I still say 6X.016's. You won't outgrow those, unless you go to twins. 8)
All these injectors won't make a lick of difference with your stock transmission. The stock autos have very sloppy converters, so at the very least, I would get a Goerend converter, to help get some power to the ground.
Postby bulltamer » Fri Jul 03, 2009 11:21 am
i dont mind if PODs are smokey
i think im gunna go with the PODs. and a hx35?
bulltamer
Postby Richie O » Fri Jul 03, 2009 12:17 pm
Im putting 297 HP through my SLOPPY converter. 8)
Postby RSWORDS » Fri Jul 03, 2009 12:21 pm
Smokey is an understatement... :lol:
I poped the little snap ring off that hold the rod to the wastegate the other day. Try driving 30 miles with a wastegate that is wide open. :lol:
RSWORDS
Users browsing this forum: No registered users and 284 guests
