'91 Cummins wrote:Get some 6X.016's and be done with it.
RSWORDS wrote:I dont think 6x16's are a DD injector. I know I would not want to do it.
Now a DD/Street Terror yes they would be nice!
bulltamer wrote:so PODs will be a good daily driver injector
can i run PODs with stock pump settings or do i have to crank up the pump
bulltamer wrote:i want sum injectors that make sum good power without breakin the bank
'91 Cummins wrote:bulltamer wrote:i want sum injectors that make sum good power without breakin the bank
POD's can be had for around $440 new, and even less used. They are dirty, smokey and hot, so if you don't mind that, then go for it.
I still say 6X.016's. You won't outgrow those, unless you go to twins.![]()
All these injectors won't make a lick of difference with your stock transmission. The stock autos have very sloppy converters, so at the very least, I would get a Goerend converter, to help get some power to the ground.
Richie O wrote:RSWORDS wrote:I dont think 6x16's are a DD injector. I know I would not want to do it.
They can be SMOKEY can't they Bobby?
Users browsing this forum: No registered users and 87 guests
