jumpy speedo
jumpy speedo
Postby 2stroke » Mon Apr 09, 2007 6:49 pm
why does my speedo get real jumpy? any where from 5 to 20 mph jumps. all the time while moving. is it a bad cable?
91 non I/C w-350 SRW
2stroke
Postby Rebel Ram » Wed Apr 11, 2007 9:27 pm
Check the plug at the trans. The pins get loose where they slip into the sockets. Then they make intermitant contact along with pulse signal from the sender causes spazed speedo. Anyway, thats what was wrong with mine.
"Big Ugly"-93 3/4 T extra cab 4X4 5 speed
"Big Hips"-92 1 Ton reg cab 4X2 Auto
"The ohwun"-2001 3/4 T quad cab 4X4 auto
Rebel Ram
Postby CAJUN 93 » Thu Apr 12, 2007 5:49 am
mine did that for about a week before my speedo sensor fell off :o . check the connections by the drivers side rear of the trans. make sure the sensor is tight to the adapter. our trucks dont have a cable.
CAJUN 93
Postby 2stroke » Thu Apr 12, 2007 5:32 pm
i dont think that i have one of those sensors. my speedo cable goes into the gear reduction thingy at the t- case.
2stroke
Postby CAJUN 93 » Fri Apr 13, 2007 7:11 am
yep, i didn't realize you had a 90. may be a broken cable. hold one end and try spinning the other. sometimes a broken cable will cause the speedo to jump at slow speeds, but not at high because the friction causes the broken ends to grip.
best way i've found to check a speedo is with a drill. undo the cable at the trans and spin with drill and have someone monitor the speedo. if it operates ok, the problem is in the trans. if not undo the cable at the speedo and spin speedo with drill (usually requires a homegrown adapter) and see if it operates ok. if so, problems the cable, if not, problems the speedo head. it also helps to have a variable speed drill
CAJUN 93
Postby dpuckett » Sun Apr 15, 2007 7:48 pm
Both my 90 and 91 had electronic sensors. Of course, they were 2wds. There are a lot of little differences like that from year to year.
I'd check the gears in the tranny and speedo adaptors. ALso, if your ratio adaptor has a grease fitting on it, stick some grease in there.
DP
Postby 90firstgen » Mon Apr 16, 2007 12:14 pm
My 90 is also an electronic sender. i could be way wrong but I thought only the 89's had cables.... I'm also 2WD
1990 2x4, 3/4 ton, Getrag, Cummins N/I
3200 Spring
Full Fuel Screw maxed (+/- 4 turns)
Injector rebuild with bigger nozzles
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
14cm Wastegated Housing
Stan's 4"
90firstgen
Postby dpuckett » Mon Apr 16, 2007 2:35 pm
BGilbert's 90 donor rig had a cable, and the turnover at 100K odometer. Weird.
