Soft brakes
Soft brakes
Postby 90FIRSTGEN CUMMINS » Tue Aug 11, 2009 6:21 pm
This past weekend i was hauling one of my farm tractors back from a show and there is a really step hill comming out of the show grounds. As i went down the hill at a low speed i noticed my brake pedal went really far down and the lights on the dash came on. Anyone know what would cause this.
1990 W250 Non I/C, Mostly stock,4 inch Ex,Fuel Screw Turned Up a Little, 727TF, 366 spring, BHAF, Borgeson Steering Shaft, Under-bed B & M transmission cooler, head lights now on relays(just added)
90FIRSTGEN CUMMINS
Postby PToombs » Tue Aug 11, 2009 6:24 pm
Blew a brake line or the ABS valve screwed up.
Postby RumbleFish » Tue Aug 11, 2009 6:32 pm
and dont forget the obvious, as pete did, and check the fluid level.
Postby 90FIRSTGEN CUMMINS » Tue Aug 11, 2009 6:49 pm
the funny thing is once i got back on the road it seemed the brakes came right back but at the low idle was the only time it was like that.
90FIRSTGEN CUMMINS
Postby Ace » Tue Aug 11, 2009 10:35 pm
Lost vacuum? Booster going south? Maybe check for vacuum leaks...
Postby dpuckett » Wed Aug 12, 2009 12:45 pm
I'd think a bad booster/ low vacuum would just make the pedal hard, not necessarily make the pedal low or soft. I could be wrong......
My money is on the ABS or master cylinder.
Postby 90FIRSTGEN CUMMINS » Wed Aug 12, 2009 6:37 pm
Master is new so what would it be with the abs??
90FIRSTGEN CUMMINS
Postby dpuckett » Thu Aug 13, 2009 9:52 am
NEW or reman? Remans are junk, and I havent had any luck with brands other than Bendix.
With the AntiStop Brakes, the dump valve cen get stuck about half open, and you fill the accumulator, giving a low, mushy pedal.
DP
Postby 90FIRSTGEN CUMMINS » Thu Aug 13, 2009 2:55 pm
Its new cause the reman i tried to get was totally wrong.
90FIRSTGEN CUMMINS
Postby cougar » Sat Aug 15, 2009 8:53 am
I am trying to remember if the RWAL had a G sensor in the control box. If there is, it may interpret down hill as a potential lock up.
01 2500 "the work truck".
cougar
Users browsing this forum: No registered users and 67 guests
