Turbo Upgrade Help
Postby Cummins Junkie » Fri Aug 21, 2009 9:08 am
The Hx35 that i have on my truck is pretty fun, but since I put bigger sticks in I need a bigger turbo. there cheap and easy to come by but I wouldnt waste ur time with the 35. Find a Hx40 or S300. Have also hurd the He351 is a very good upgrade, Im thinking of going that rout. Hope this helps
Cummins Junkie
Postby foxracing5578 » Fri Aug 21, 2009 5:43 pm
ktekst wrote:It is mainly a toy, there might be a few occasions when it will be used for towing.
How hard are the hx40s to come by?
i got my hx40 for $100 on ksl classifieds, but thats here in utah. and i've seen a few on there since i got mine
90 w250 non i/c, denny t fuel pin, 3200 gov spring, lil tinkering with the pump nothin special
foxracing5578
Postby ktekst » Sun Aug 23, 2009 8:43 am
foxracing5578 wrote:i got my hx40 for $100 on ksl classifieds, but thats here in utah. and i've seen a few on there since i got mine
Yea i try to check local classifieds like craigslist regularly but dont have to much luck. I also have a buddy at a big truck junkyard whos trying to "find" one for me. :)
ktekst
Postby TTipswprd » Sun Aug 23, 2009 10:26 am
what model trucks did the hx 40 come off of?
1992 w250 4x4, pump tuned, custom exhaust, intake, and dennyT fuel pin, cooler tubz, 5x.014's from SDX
TTipswprd
Postby Tacoclaw » Sun Aug 23, 2009 1:35 pm
bgilbert wrote:There are a ton of hx40 variations. The one you want will come from a newer 24 valve c-series 8.3 and will have a 16cm wastegated bolt up housing.
This is what I came up with when I read through The Good Stuff a while ago.
Postby ktekst » Tue Sep 01, 2009 7:46 pm
Can someone who has a Hx-40 that is the right combination (60/65/16) give me their Assembly number, Serial Number, Customer Part Number, and Turbo Type (which i know should be Hx-40 but i dk if there are any pre of post letters)
I ask this because Im going to end up buying a new or reman turbo from one of my dads wholesale parts wharehouses and its basically impossible to order anything without knowing every which part number.
Thanks in advance guys. :grin:
ktekst
