6.7 turbo
6.7 turbo
Postby TTipswprd » Sun Aug 30, 2009 4:22 pm
has anyone ever put a turbo on their truck of a new 6.7 dodge? dont know if its possible but thought i would ask.
1992 w250 4x4, pump tuned, custom exhaust, intake, and dennyT fuel pin, cooler tubz, 5x.014's from SDX
TTipswprd
Postby matchew » Sun Aug 30, 2009 4:49 pm
There are a few that are trying...now controller available at this time, so you have to dream up your own. I've been hearing bad things about the vanes getting sooted up on them though.
92 1 ton, 7" lift 37 military MT's on Hummer Alcoas, HE341, 4" downpipe to tailpipe, killer front bumper, 14mm H+R, +40 injectors, 03 dodge seats, loud tunes. 'Custom' Rustoleum paint.
matchew
Postby c12h26 » Sun Aug 30, 2009 5:10 pm
I put one on my truck and I like it,I have not came up with a way to control the vanes yet so it is in the full open position all the time,it spools a little slow but when it lights it pulls hard
here are some pics
1991 D250 reg. cab 518
4" turbo back,pump turned up,bumped timing,intercooler,HX52,366 spring,ground AFC lever,piston lift pump,Goerend converter,M/T ET street radials,nitrous,lowered.
c12h26
Postby burnt_servo » Mon Aug 31, 2009 11:29 am
c12h26 ;
how slow is the spool up ? do you have something you can compare it too ? ( like maybe the stock turbo / stock housing ) .
i've got one of those turbo's too , i was thinking of limiting the movement of the vanes so it wouldn't close down too tight ( to keep the turbo from overspooling ) , then using something like a regular waste gate actuator to move the lever .... ( i'm thinking of something much much larger in diameter than a regular waste gate actuator , so it will be much more sensitve to pressure changes )
then maybe add a external waste gate that would kill the exhaust pressure at lets say 40 psi
'93 w250 .... stock ...
burnt_servo
Postby burnt_servo » Mon Aug 31, 2009 11:31 am
btw has anyone thought of using exhaust back pressure to control the vanes of one of these turbo's ?
burnt_servo
Postby TRENDZ » Mon Aug 31, 2009 6:23 pm
I also am planning installing one of these turbos. I see you have the actuator exposed, and no coolant running through it. Have you manually moved the lever with the engine running? What were the results? How does the turbo sound?
I was also considering a back pressure based control with a manually adjusted travel limiter. If anyone gets one/has one of these working with some control, please post! I have one, but the truck is so far apart right now that it will be months before I get to try it.
The compressor wheel in this turbo looks real nice, Im sure it is capable of some good power.
91 d350 1/2" supply lines, 2nd gen lift pump, regulator, 366, screwed, homebrewed afc pin, linkage mods, ported head, ported ex manifold, 351ve electrically controlled, 3" boost tubes, 2nd gen I/C, 4" ex, goerand
TRENDZ
Postby Fnschlaud4620 » Mon Aug 31, 2009 6:38 pm
check out this link,
good info on a manual VGT controller.
http://www.competitiondiesel.com/forums ... hp?t=48106
Fnschlaud4620
Postby TRENDZ » Tue Sep 08, 2009 9:24 pm
O.K. I made the turbo fit the manifold today. It was a lot of screwing around, but it is a nice clean look.
First step was to drill the 4 mounting holes on the turbine inlet, so I could tap them to 1/4" pipe.
Second step was to install pipe plugs in these holes( I used the plugs with the four sided extension, than cut off the extention, so I had a complete surface for machining)
Third step was to mill the entire flange flush so I had a nice fresh surface to work with.
Next, I drilled and tapped holes in the fresh surface in the "T3" pattern, using a 3/8"coarse tap.
I installed 4 studs in the turbine, than went to work on the manifold.
If you look at the stock manifold, you will notice that the upper side would work with the new studed turbine(if drilled to the correct size), but the lower part of the flange has blind holes. My manifold just needed that "extra" material behind the flange removed to install the new turbine with studs, and there is JUST enough room to get the nuts in there now.
Now that that's done, it's time for the down pipe and cold side plumbing....
TRENDZ
Postby SicNick » Sun Sep 13, 2009 9:18 pm
Lets keep this thread rolling guys, I just won a $100 HE351VE on Ebay! I hope I can make this thing fit in my K30, kinda tight by the AC box :shock:
1984 K30 powered by 1990 6BT
SicNick
Postby TTipswprd » Sun Sep 13, 2009 9:33 pm
yes this is very interesting but past my knowledge though.
TTipswprd
Postby TRENDZ » Mon Sep 14, 2009 3:26 pm
some pics of how I did mine here...
http://www.dieseltruckresource.com/dev/ ... 45625.html
TRENDZ
Postby SicNick » Tue Sep 15, 2009 7:50 pm
Link doesn't work for me, says it can't load the page!? Would you try posting again? Thanks! :P
SicNick
Postby TRENDZ » Wed Sep 16, 2009 5:26 pm
Fixed. sorry
TRENDZ
Postby lectro_static » Fri Oct 16, 2009 9:06 am
Any more done on these installs? I have one now too but am not sure that it will work very well with stock injectors, any thoughts?
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby SicNick » Sun Nov 29, 2009 11:20 pm
Turbo is hanging off the truck now, pics soon
SicNick
Users browsing this forum: No registered users and 205 guests
