Ace wrote:I run a 60mm hybrid upgrade w/full 4" exhaust, Powerstroke intercooler, ATS manifold, stock I/C injectors and my VE is NOT turned all the way up. Water meth is the only thing that keeps it around 1200 EGT under sustained load, hovering at 25psi boost. The 12cm exhaust housing isn't helping that, but I suspect that will be less than 50degrees overall difference under sustained pulling conditions, runnning in the powerband at 2000rpm. I need to re-install the 16 one of these days and make some notes on that. So I'm probably not even at 300hp and I think I need a bigger turbo.
Ace wrote:I gotta give you credit for all the research, I'm sure you know more about turbos than I do by now! But you may be over-thinking this a tad. You need a bigger turbo if you want to tow with it to cool more fuel. It needs to flow more air more efficiently. Exactly which one you choose is not that important as long as it does it that.
The Hi1Cs that came on these trucks stock are great little turbos, well matched to the stock tune - 160hp. Match the turbo size to the amount of fuel you want to burn for your hp goal. My choice for a low budget upgrade would be a used HE351. I'd get a new Super40 if I could easily afford it. Maybe you just need a 16cm housing for the 40 you already have?
fergavs wrote:I would run a 62mm comp with a 14cm exaust housing. This will give you good spooling (probably better then the big exaust housing you have now) and it will cool up to 450rwhp. On top of that I would add the powerstroke all aluminum intercooler. If you added a set of DDP 80hp sticks you would have a great towing setup that will keep things cool. Just be sure to be conservative on your pump settings. Then when your not towing and you want to go play just crank up the pump and leave rubber strips all over town. lol. Just my opinion but it will work very well based on my experience.
