JAyers 516hp/959tq at SDX 09
Postby JAyers » Mon Aug 31, 2009 10:18 am
Heres the vid of the horribly tuned truck of mine. :oops: I thought it was tuned better but hey thats what a dyno is used for.
Im gonna work on getting the afc tuned in alittle better and hopefully I can get that HT4B to light sooner. If not then im either goin to step down to a HT3B or rework my plumbing for a S400. Even with the slow spool up dave said he still saw 80psi, I guess I tightened up that allen screw more then I thought :shock:.
Ill have the dyno sheet up today sometime.
And can anyone tell me why when Dave let off the throttle the truck launches out a nice black shot of smoke at the end of the runs? http://www.youtube.com/watch?v=_Iv8NCmzqwA
93 W250...balanced, ported, and fresh. Equipped with 14mm h/r, A1000 supply, Hamitons 188/220, T4 stainless manifold, s360/68/.91ar - s475/74/1.1ar twins, and Kennys dd clutch.
JAyers
Postby bgilbert » Mon Aug 31, 2009 1:56 pm
Keep up the good work and R&D Josh. Won't be long and you'll be in the 600hp VE club 8) . Like I mentioned to you at Scheid's, I'd bet a hx35-12 over 3B or small S400 would net close to 600hp. Quick spooling twin set might be the ticket for us VE guys.
Bill Gilbert
Postby KTA » Mon Aug 31, 2009 4:33 pm
Sounds like your wastegate is too tight. My truck made more hp with 60psi than it ever did at 80.
Postby TWorline » Thu Sep 24, 2009 6:19 pm
Good job Josh!!! :salut: Was Dave a little apprehensive about getting back in your truck?
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby JAyers » Thu Sep 24, 2009 6:31 pm
Thanks Tim! I had it repainted so he wouldn't recognize it....lol....however he did ask about where the air kill was before I had a chance to show it to him. :oops:
JAyers
Postby TWorline » Thu Sep 24, 2009 6:55 pm
maybe he recognized the seat! ;-)
Tim Worline
TWorline
Postby jmono » Mon Oct 19, 2009 1:28 pm
That is a cool vid!
Someday for me! That vid makes me anxious! I wish I had a money tree...... :'(
1990 Dodge W250 R/C 4x4, Non I/C Cummins, 727 auto, autometer gauges, ground fuel pin, 366 spring, maxed out ve, straight pipe, 2ish" lift, and 35" BFG M/T's on 16.5" rims.
jmono
Postby 92 D/UNIT » Tue Oct 27, 2009 7:55 pm
Congrats! :D
388/886
92 D/UNIT
Re: JAyers 516hp/959tq at SDX 09
Postby gobigorgohome » Thu Mar 25, 2010 10:46 am
hey jsut wondering but how much money do you have wrapped up in that engine of yours??? curious cuz thats where i wanna be with my truck some day and i would like to know what it will cost me on a rough estimate, thanks :D
gobigorgohome
Return to Competition
