LP question...
LP question...
Postby MMeier » Wed Oct 07, 2009 11:07 am
... is it possible for the LP to suck oil into the fuel system, yet not have fuel get into the oil ?? :?
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Postby ahale2772 » Wed Oct 07, 2009 11:22 am
there shouldent be any oil actually bathing the lp only oil flung off of the cam if its a diphragm style some oil can get on to the arm that contacts the cam but that arm is seal off of the diagfram itself ...other wise fuel would leak into the crankcase as well ....i could be wrong hopefully someone else will chime in
Postby Ace » Wed Oct 07, 2009 12:01 pm
No, because even in diaphragm failure mode, the fuel side will have positive pressure differential, sending fuel to the crankcase. I suppose it is not outside the realm of possibilty for that to be reversed in the case of an engine with some extreme blowby condition going on. But then you'd have bigger problems to worry about.
Postby ahale2772 » Wed Oct 07, 2009 2:45 pm
yes but how is the fule getting from the diaphram to the crancase? isnt the arm on the pump sealed?
Postby PToombs » Wed Oct 07, 2009 5:38 pm
No. It's the same as a gasser fuel pump. Just a diaphragm that goes up and down, pushing and pulling. When it gets a tear, it just pushes fuel into the base.
Postby Richie O » Wed Oct 07, 2009 6:02 pm
PToombs wrote: Just a diaphragm that goes up and down, pushing and pulling. When it gets a tear, it just pushes fuel into the base.
Man, a sentence with diaphram, up, down, pushing, pulling, tear in it. He may be talking about a lift pump but his mind is elswhere. :D
Postby PToombs » Wed Oct 07, 2009 6:08 pm
What a Mainerd! :roll:
Maine+nerd= Mainerd ;)
:lol: :lol: :lol:
