Injector advice?
Injector advice?
Postby KRB64 » Mon May 07, 2007 7:57 pm
Looks like I'll be needing some new injectors (OK, read "wanting" new injetors). http://www.dieseltruckresource.com/dev/ ... p?t=149933
I was thinking 190s but I'm not up on this. What about EDMs? What else is out there?
Not looking for smoke. Just need HP and MPG. Dauily driving and towing.
What say ye?
'92 W250 CC LE, auto, OD on shift, 3.54 limited; boost/PT pyro/tranny, oil temp, fuel press, tach; Bosch 190s, Ol' Smoky, 366 spring, full fuel, pull cable, 1/8" bump, synthetics, Borgeson, aFe, 16cm house, 4" pipe, AT cooler, ton shoes, ext reg...
KRB64
Postby CAJUN 93 » Tue May 08, 2007 7:48 am
i have 185's in mine a really like them. i've read there's not much difference in the 185's and 190's but i defer to the experts on this. i do tow some (up to 10k or so) and don't have heat problems. mileage is about the same as stock injectors. you'll be happy with the change.
as for buying, i picked mine up second hand so i'm not much help there. all the usual diesel shops list 185's, 190's, and i saw 210's listed somewhere.
daryl
CAJUN 93
Postby PToombs » Tue May 08, 2007 11:49 am
190's are good. Mark at PDR was trying to talk me into some. Better mileage, more power. There are more, smaller holes than stock, so you get better atomization.
By the way, I went to 370's. :twisted: :D
Postby JLeonard » Tue May 08, 2007 11:53 am
I have Bully Dog +50s. I don't know if they are still available. I get the same mileage as with the stockers provided I drive sanely, and they didn't smoke much at all till I started grinding on the fuel pin :D
91 D250 w/modified Cummins, 89 D250 donor (future boat engine)
JLeonard
Postby KRB64 » Wed May 09, 2007 2:29 pm
The local Cummins shop here wants $695 for a set of "40hp Bosch injectors" whatever that translates in to. Stockers are $152 each.
This guy on ebay has them for $355.
:D
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... :IT&ih=009
Anybody dealt with him before?
KRB64
Postby RumbleFish » Wed May 09, 2007 6:22 pm
That who I got my pod's for my dually from. Cheapest I could find too. I called back later to get the adapters for my non I/C head and he was really friendly. I wouldn't hesitate to deal with them again.
Postby KRB64 » Thu May 10, 2007 2:30 am
He's got a 100% positive feedback. Was there anyway to tell if the injectors you got were the injectors you wanted? Model numbers etc? Like are they performing as expected?
These're the same for half what the Cummins place wants. :wink: From what I can tell they are the "190s".
KRB64
Postby PToombs » Thu May 10, 2007 3:55 pm
KRB,did you check PDR?
Edit, $399 for 190's, before shipping!
Postby KRB64 » Thu May 10, 2007 5:57 pm
PToombs wrote:KRB,did you check PDR?
Not yet wild man. Thats a good price. Are they still decent after Piers left?
KRB64
Postby PToombs » Sat May 12, 2007 5:20 pm
Still a good place to deal with. I usually talk to Mark, he's been there awhile. 8)
We need a hyper smilie! :wink:
Postby seeker1056 » Sun May 13, 2007 4:31 am
I have a slightly used set (5000 miles) of POD's for $325 obo plus shipping if you like.
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby KRB64 » Sun May 13, 2007 5:06 am
I'm staying away from the PODs I think. I'm worried about EGTs when towing/hauling. From what I've gleaned I think the 190s are best for my setup.
I located my bad injector (I think) pulled it and its a Bosch. Says "937" inside an oval border. Up top is has "8965". Also says "KDAL 59 P 9 171 245 bar"
I pulled an injector from my brother's donor and its the same except instead of "171" it has a "266" and the copper washer is thinner. I was going to use this until I got new ones but since its not identical I don't think I should. :cry:
Anybody know what these numbers mean? :? ! And what'll happen if I use it with the other 5 "171"s? :?:
KRB64
Postby PToombs » Mon May 14, 2007 5:21 pm
Ask Scott, (Greenleaf) he has the book with the numbers. He can tell you the difference. Or you could swap them all for now.
Postby KRB64 » Tue May 15, 2007 7:35 pm
Ordered a set of 190s from PDR :D
KRB64
Postby KRB64 » Sun May 20, 2007 3:39 am
PToombs wrote:Still a good place to deal with. I usually talk to Mark, he's been there awhile. 8)
Well I got the 190s and they are in and running. Only prob is getting the lines to quit leaking :x . May be my imagination but I think its running quiter. The RPMs are down by 50.
Ordered a 3200 spring too but will wait a little while to install.
Thanks fot the tip Toombs :wink:
KRB64
