WH1C downpipe?
WH1C downpipe?
Postby dazedandconfused » Fri May 18, 2007 5:32 pm
Is the downpipe for a WH1C the same as on a HX35 and HY35? Were is the cheapest place to get a 4" downpipe for this? Is this a better charger then a HY35? Who has done the HTT upgrades to theres? Sorry for all the questions guys but I need some awnsers.
Andy
Postby Philip » Fri May 18, 2007 9:07 pm
The H1c and a HX35 use the same exhaust housing. So if your using the normal nonwasted gated housing. Then they both would use the same down pipe.
As far as the Hy turbo. I have no idea about it.
I think Stans is the only shop making a true 4" down pipe. I installed a 4" exhaust on my truck a while back. Stans was the only place I could find it. There a quite a few places to get a 3.5" down pipe. Then they step to a 4" system from there back.
Postby dazedandconfused » Sat May 19, 2007 7:34 am
Thanks for the info, I was told the HY and Hx are the same downpipe so that should work. Do you have a link to a site for that downpipe?
Andy
Postby gman07 » Sat May 19, 2007 10:50 am
I think later model HX35's, as well as the HY35's, have an elbow built into the back plate on the exhaust housing. The earlier HX35's, the WH1C's, and H1C's have v-band outlets that will attach directly to your stock downpipe.
gman07
Postby dazedandconfused » Sat May 19, 2007 11:41 am
gman07 wrote:I think later model HX35's, as well as the HY35's, have an elbow built into the back plate on the exhaust housing. The earlier HX35's, the WH1C's, and H1C's have v-band outlets that will attach directly to your stock downpipe.
You are correct after looking at my charger that is the way it is.
Postby PToombs » Sat May 19, 2007 5:46 pm
You can use your exhaust housing on either turbo. I recently put an HX-35 on my truck, and didn't even remove the housing.
Postby Philip » Sat May 19, 2007 9:32 pm
If you go with a later exhaust housing. They are waste gated. Our stock down pipe needs to be shorted about 1 1/4" to fit properly. The housing with the turn down I don't know what needs to be done.
Here is a link for stans.
http://www.stans-headers.com/diesel.htm
Here is a link with a pic of my down pipe from stans.
http://s166.photobucket.com/albums/u97/ ... t=pic1.jpg
Postby dazedandconfused » Sun May 20, 2007 6:30 am
Thanks for the help, I appreciate it.
Andy
