what is a borgenson shaft
Postby james-93-12valve » Sun Dec 06, 2009 9:49 pm
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
Postby rmauto1 » Sun Dec 06, 2009 11:27 pm
http://www.genosgarage.com/prodinfo.asp ... ORG-000940
This is a link that shows what a borgeson shaft is. It is a quality shaft, that uses a needle bearing u-joint, instead of the sloppy factory pot coupler. Hope this helps.
Randy-
rmauto1
Postby peobryant » Mon Dec 07, 2009 1:08 am
Postby pulltilbroke » Mon Dec 07, 2009 7:49 pm
Or you can build your own and save about 150$
Heres the one I built
Postby rmauto1 » Mon Dec 07, 2009 7:53 pm
pulltilbroke, is that chain in the first pic, a limiting strap to keep from breaking motor mounts?
rmauto1
Postby pulltilbroke » Mon Dec 07, 2009 9:25 pm
Yep, I need to engineer/fabricate a new mout to eliminate the chain but still keep cushion in the mount. I think solid mounts woud shake the rest of the truck apart
Postby rmauto1 » Mon Dec 07, 2009 9:47 pm
You should try to find someone that repairs soft ratchet straps, and have them sew you up a short, fat little bugger with some sort of eyelet or loop on the ends, to tie it together. Should be strong enough. Would be cleaner, and softer than the chain. Up here at the big swap meet by me, there is a lady with a booth that repairs snatch straps and ratchet straps super cheap, while you wait. Might be a trick way to go. Just my two cents.
rmauto1
Postby RumbleFish » Tue Dec 08, 2009 1:12 pm
so lets hear how you built this ujont style steering shaft already!
Postby mprmn08 » Tue Dec 08, 2009 5:17 pm
RumbleFish wrote:so lets hear how you built this ujont style steering shaft already!
x2
do you have the part number for the u-joint you used?
mprmn08
Postby pulltilbroke » Tue Dec 08, 2009 7:46 pm
The joints are available from Speedway motors
This is the joint I used
http://www.speedwaymotors.com/Speedway- ... ,6632.html
The shaft I used was out of an 86 gasser. It was 2 1/2 inches longer then the original shaft off of my truck.
The gasser shaft measured 19" from the column side of the rag joint with the rag joint still installed to the spot where the shaft necks down, whereas my original shaft measured 16 1/2 from the same points of reference.
I cut the shaft at 18 3/4 and the shaft side of the yoke is at 17 3/4(where I welded it)
I'd go out and take some more pics but it too friggin cold and theres about a foot of snow on the ground
Postby lectro_static » Tue Dec 08, 2009 7:50 pm
http://www.speedwaymotors.com/Speedw...ound,6632.html
Bad link please let us know as I want to get mine done too
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby pulltilbroke » Tue Dec 08, 2009 7:56 pm
Linky fixed
Postby pulltilbroke » Tue Dec 08, 2009 9:02 pm
Okay I lied I did go out and snap some more pics just cuz I had to run up to the gas station to get a Milky Way and a pack of smokes
And this is what it looks like outside right now, cold as hell with 30+ mph winds
Postby 1STGENFARMBOY » Tue Dec 08, 2009 9:55 pm
do you still have the rag joint in there i can't tell (you are sooooo deadecated to us ) :lol: luckily i'm just a little south of that cold weather it's just rainin here :)
Postby pulltilbroke » Tue Dec 08, 2009 10:16 pm
Yep, Rag joint is still in there. kinda covered with snow in the pics
