sticky request
Moderators: Greenleaf, BC847
sticky request
Postby smoky beast » Mon Jan 08, 2007 1:26 pm
how about have a sticky section, like over on DTR, may even with a little more info.
thanks
smokin okie
1991 D250,non-intercooled,reg cab,5 speed,3:55, flatbed,fuel screw and starwheel maxed,PDR fuel pin, 3200 gov spring,ASA intake w/AFE filter,HTT stage III, 16cm housing,3" straight pipe w/6" tip,AutoMeter EGT+Boost, Mopar RPM guages
smoky beast
smoke screw?
Postby MUDDY » Mon Jan 08, 2007 1:36 pm
not familiar with it. give me a little detail on it.
93 D-350 dually
90 W-250
FOR IDAHO EVENTS WATCH
MUDDY
Postby MUDDY » Mon Jan 08, 2007 1:50 pm
got your pm smokin okie.
thanks for the info 8)
93 D-350 dually
90 W-250
MUDDY
Postby flashgordon » Fri Nov 16, 2007 3:32 pm
MUDDY wrote:got your pm smokin okie.
So, did we end up with a sticky? and if so how or were do i find it.
Flash.
flashgordon
Return to 1st Gen.org suggestions
