tps on a 2001 2500 cummins dodge
All of 'em
Postby stock91w350 » Sat Jan 30, 2010 6:33 pm
my bother has a 01 cummins built to over 500hp and 1000ft lbs to the wheels. hi throttle posistioning sensor went bad, he bought one from a company on the internet and in the instructions to install we had to ajust the tps useing a volt meter, after it was all done his idle is going up high and low when u tap the peddel also his coolent gaughe is going up and down from cold to hot, any ideas? the weekend mechanic that helped said it was prolly his heat sensor and if so it would wanna keep putting the truck on high idle, sound rite? thank you
91 w350 5spd dually. 5"stack, fuelpin, starwheel all in, smoke screw all in, homemade cold air intake
stock91w350
Postby stock91w350 » Tue Feb 02, 2010 5:05 pm
wow! he plugged it in today to see if i would throw a code and it threw 18!! something musta went bad all at wonce
stock91w350
Postby Billy Boy » Tue Feb 02, 2010 6:06 pm
My brother's 02 with twins had a similar problem. He thought it was a TPS as well. When he plugged it in, it threw a bunch of codes. He replaced the VP pump and the ECM at that time. Not sure if the pump or the ECM was the actual issue though.
1989 Dodge D350 Dually, Non I/C
Billy Boy
Postby PToombs » Tue Feb 02, 2010 6:18 pm
If you put a VE on it you wouldn't have most of those overvalved problems. ;)
Postby burnt_servo » Wed Feb 03, 2010 4:15 am
PToombs wrote:If you put a VE on it you wouldn't have most of those overvalved problems. ;)
it looks like it might be a easier swap than a p pump swap
'93 w250 .... stock ...
burnt_servo
Postby stock91w350 » Wed Feb 03, 2010 7:50 am
was one of the symptoms befor he fixed it a dead pedal after it wrmed up? after my brothers truck warmed up it was like the throttle cable wasent even hooked up
stock91w350
Postby Billy Boy » Wed Feb 03, 2010 8:34 pm
I can't recall if there was a complete dead pedal feeling for him. His initial diagniosis was a TPS though, and that was definitely not the problem in the end. I think it was the ECM that actually solved his problem, but I can't say for sure.
Billy Boy
Return to Other diesels
