Do you have a clean idle with larger injectors?
Postby Dean » Wed Jul 04, 2007 7:04 pm
Hi
I am wondering if anyone with larger injectors has a no smoke (stock like) idle?
Thank you
Dean
Dean
92 W350 5 speed, F-450 rear frame sectioned on with Dana 80 rear, 370 injectors, HTT stage 4/16cm, Pump and timing bump, Hydro disk brakes, Porsche e-brake, Small sleeper for my dog, Alu flatbed.
Dean
Postby ford69557ci » Wed Jul 04, 2007 8:24 pm
i am runnin ddp stage 4's and i dont have any idle haze and i am gettin ready to do a set of new era custom edm's and they told me i would have very little or none with those
ford69557ci
Postby Fnschlaud4620 » Wed Jul 04, 2007 10:02 pm
The PowerpartsEngineering 435s have a huge black cloud when it starts and then they are perfectly clean at idle cold or warm.
if you drive very carefully thry will stay clean too. and at highway cruse they are clean, but put the hammer down and holy SMOKE !!!!!!!!!
Fnschlaud4620
Postby JLeonard » Thu Jul 05, 2007 5:08 am
I am running Bully Dog + 50s and have zero smoke at idle
91 D250 w/modified Cummins, 89 D250 donor (future boat engine)
JLeonard
Postby KTA » Thu Jul 05, 2007 5:24 am
My injectors idle haze, it is not real noticeable unless its is in headlights at night or on a bright summers day you will see it pretty good. I don't care that it hazes though, so its not a problem for me. 8)
Postby wannadiesel » Thu Jul 05, 2007 3:49 pm
Mine haze at idle when the engine is cold. Warmed up it's clean.
Best dyno: 408/844
wannadiesel
diesel guru
Postby ford69557ci » Thu Jul 05, 2007 4:05 pm
i had pod's to for my first set and they hade a haze at idle my ddp's move alot more fuel so why dont they haze??
ford69557ci
Postby gman07 » Fri Jul 06, 2007 9:10 am
I think the reason the POD's haze is because they're not exactly designed for our application. I think POD's have a higher pop pressure, as well as a slightly different spray angle.
gman07
Postby PToombs » Fri Jul 06, 2007 2:10 pm
POD's are like a toilet bowl. They just dump a lot of fuel fast, not as good atomization. I can't remember the size, but they only have 4 holes.
